3.42, 3.73 or 4.10?
Old Jun 18, 2003 | 04:31 PM
  #16
Wild1's Avatar
Mine were loud at first, but now it is quiet! I had a tech install and adjust the preload. Also, I have GM Motive gears with are double-lapped (supposedly to keep them quiet) as opposed to the Strange Gears which are straight cut for strength. Buddies in the Camaro Club ride in my car and can't believe it after I tell them. For RPMs, at 80 MPH I'm revving 2350 RPM instead of 2000 RPM... Manual 6-Speed.
Also, you have to wear them in gently with no hard launches, smooth shifting, and stay below 50 MPH for 100 miles. I didn't believe it but they wore in VERY smooth and it is quiet.
Old Jun 19, 2003 | 01:52 AM
  #17
lt4 fd's Avatar
I dont go to the track ever maybe if someone drug me but I would never go on my own will and dont get in too many races, just like to have fun on my own with my car really, whats everyone think about 4.56's I know thats one steep freakin gear but I only city drive so I can actually use 6th... someone talked about getting them and said they were amazing, then someone else who already posted i think altjar said he has 4.33's and loves them... just curious...
Old Jun 19, 2003 | 10:40 AM
  #18
ZZtop's Avatar
Well it sounds like it's hands down 4.10's. So my quesiton to yall then, is can you get a decent 60' with 4.10's and street tires adn how much worse is gas mileage? Also, based on my mods shoudl I go with gears or headers as a first mod? Thanks a million yall.
Old Jun 19, 2003 | 12:41 PM
  #19
Wild1's Avatar
Well, at 80 MPH I rev 350 more RPM. I lost about .5 MPG in city driving.
Old Jun 19, 2003 | 02:22 PM
  #20
atljar's Avatar
I have never gone to the track with 4.33 and a true street tire. I run Nitto DR for my everyday tire, and went 1.78 60' on a lowered car with those. Not too shabby
I would recommend the 4.33 gears to anyone, but not with the stock 10bolt. You will break that within a few weaks. Also the 4.33 gears were selected to match my cam, which likes to rev pretty high. They make up for the lost bottom end, and get you into the powerband quickly. With the stock cam it was really wasnt spread out well. Tons of pickup on the lowend. You could put a few cars on anyone in a heartbeat, but it seemed like it fell on its face up top. Maybe it was my imagination???
Old Jun 19, 2003 | 02:31 PM
  #21
Brettinator's Avatar
4:56 gears are great on a car with 27x13.5 ETs and a Ford 9" or Moser 12 and a stroker car that's running mid 11's. If your an automatic and running that gear you'll be hurting on the highway without an overdrive. I'd say 4:10 gears but not sure what your running in your car.
Old Jun 19, 2003 | 04:57 PM
  #22
lt4 fd's Avatar
Nothing special on my car at all yet its a 6 speed and everyone likes the 4.10's just wondering why not 4.56? Again if it helps its totally street driven, dont care about highway, very ocassional street race usually from a 40 punch or something... I figure with that steep of a gear 5th is about what 4th is in a 3.42 so I guess it wouldnt really fall on its face up top it would be similar to a 3.42 just always a gear higher in the gate and I guess if you had any traction, I have nittos, and you went from like a very slow punch where you were in 2nd or 1st gear you get a pretty huge jump. Although I dont think I would bother launching hard for fear of breaking something, i dont care i never launch anyways.
Old Jun 19, 2003 | 05:15 PM
  #23
IrocManiac's Avatar
I've got my stock gears and like them but I have thought about doing the 4.10s...all you guys saying it'll cause a major vibration why will switching to 4.10s cause a major vibration?
Old Jun 19, 2003 | 06:37 PM
  #24
Wild1's Avatar
They only make noise if the pre-load is off spec. But if it is done right, you'll never know they are there. It's true, I give rides to people in the Camaro Club and they don't know there are 4.10s there... factory quiet. No vibration either... just wear them in for the first 100 miles. No hard launches, stay below 50 MPH, and change your speeds. After the first 100, I slowly start to drive more normally and after about 300-400 it got super quiet. I had mine installed at Diff Werks in Riverside.
Old Jun 19, 2003 | 10:46 PM
  #25
atljar's Avatar
The 410s cause driveshaft vibration b/c you are spinning the shaft much faster to go the same speed. Nothing a new DS wont fix.
Old Jun 19, 2003 | 10:53 PM
  #26
IrocManiac's Avatar
Thats what I figured everyone was getting at...however, why wouldn't I get the same vibration at 80mph that you would at 60mph turning the same rpms? See what I'm saying? My TA is solid even at 115mph redline in 4th so I just don't see why it'd vibrate in 6th turning 2000rpm?
Old Jun 19, 2003 | 11:31 PM
  #27
StreetZ's Avatar
This is a stupid question, but I just got my car last week. How can I find out what gears my car has (in sig) .....do all M6's come with 3.42's?
Old Jun 19, 2003 | 11:37 PM
  #28
IrocManiac's Avatar
All M6s 94 and up come with 3.42
Old Jun 19, 2003 | 11:44 PM
  #29
Wild1's Avatar
I've had mine up to 140 MPH no problem. Disclaimer, I race in the Silver State Classic races in Nevada. No vibrations with the 4.10s. Perhaps if you have an "ify" situation with a borderline vibration, the perhaps the 4.10s amplify the vibration. There are so many reasons for vibrations (Wheel balance, Wheel True-ness, Tire craftsmanship, bearings, lug torque uneven, Improper installation, pre-load off, defective part/component, driveshaft imballance, slightly twisted axle - not common but it happens, etc.). Anyways, if a vibration occurs, I wouldn't first blame the 4.10s. I wouldn't be running the speeds I do for as long as I do if I had any vibration.
93 RedBird
Nov 15, 2015 08:24 AM
SEOJustin
Sep 24, 2015 04:39 PM
cristian1311
Sep 12, 2015 08:16 PM
Z28amustangklr
Jul 18, 2015 11:05 AM
