What exactly is the optispark?
Old Jun 19, 2003 | 04:41 PM
bigfoot2471's Avatar
Question What exactly is the optispark?
Ok i know this is a stupid question i have gotten confused on exactly what it is. i have been reading past posts about it. and i am just getting more confused. i thought it was something then i read something else and now im just not sure. thanks a lot for your help.
Old Jun 19, 2003 | 04:52 PM
It's the distributor.
Old Jun 19, 2003 | 05:14 PM
ibanez6rg's Avatar
It's an optical distributor.
Old Jun 19, 2003 | 05:53 PM
eyeoutthere's Avatar
Can you give us more info than that? I know the opti is a distributor but I don’t know what makes it better than a conventional distributor.
Old Jun 19, 2003 | 06:00 PM
carnutz's Avatar
It is mounted on the front cover of the engine(timing chain cover) under the water pump. It is driven off of the camgear or the front of the cam. The low hood line does not allow a conventional dist. there is just not room. I t houses a engine position sensor of sorts so the computer can control timing, there is a small wheel with 360 holes and a sensor that sees the holes in relation to engine position. and then distrudutes the spark( that comes from the coil) to the corrosponding cyl via the "cap and rotor"
Hope that helps, if you still do not understand do a serch on optispark and you will find a butt load of stuff, try the same on google there is a good site where a guy has tore one apart.
Old Jun 19, 2003 | 06:30 PM
ibanez6rg's Avatar
I believe the sensor is on the crank (crank position sensor)
Old Jun 19, 2003 | 06:52 PM
Crank position is also determined by the opti on the pre-96 cars, since pre-96 cars have no crank position sensor.
Old Jun 19, 2003 | 07:36 PM
how hard is opti to replace. does anyone know where i could get a diagram of it. how long does it take to do. what else needs to be done when you change it. i have done some stuff but am not sure if i would be able to change it myself.
Old Jun 19, 2003 | 08:11 PM
This site will give you some idea.
Old Jun 20, 2003 | 12:02 AM
can driving around with a bad opti cause further damage to my car?
Old Jun 20, 2003 | 12:09 AM
Larnach's Avatar
Yes its possible, you can get detonation, etc. etc. which takes a heavy toll on the pistons.
Jeff1904
Jun 5, 2016 05:00 PM
PopoFormula
Oct 12, 2015 04:19 PM
football4life
Oct 4, 2015 07:48 AM
colts0455
Sep 27, 2015 01:07 PM
Z Power
Sep 19, 2015 11:19 PM
