3.4 to LT1 swap, need A/C help
Old Jun 8, 2006 | 08:39 AM
EKO's Avatar
EKO
The compressor won't kick on. I'm still using the V6 fan. Is the PCM looking for another fan before it will turn the compressor on?
Old Jun 8, 2006 | 08:45 AM
DontMixWithRice's Avatar
Re: 3.4 to LT1 swap, need A/C help
maybe.
i swapped out the radiator and the fans....and im still having ac problems!
Old Jun 8, 2006 | 08:11 PM
EKO's Avatar
EKO
Did you wire in another relay and circuit for the other fan? I was looking at a wiring diagram and the PCM has two fan circuit inputs and outputs.
Old Jun 8, 2006 | 08:24 PM
OutKast's Avatar
I swapped the entire harness, actually both of them, engine and body harness in the engine compartment. A/C worked great for years...
Old Jun 8, 2006 | 10:24 PM
EKO's Avatar
EKO
That's probably where my problem is. The PCM must want another fan.
HectorM52
Jun 23, 2016 08:42 PM
rocketman051894
Jan 30, 2015 03:23 PM
SpeedJunkee
Jan 27, 2015 10:02 PM
Jason Short
Jan 19, 2015 06:34 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
