2nd time broken down. Car will not start even w/ spark
Old Apr 19, 2007 | 01:54 PM
emerica4601's Avatar
Whats up guys,
Well, heres what happened. I'll start off by saying my car runs quite rich and i need to get retuned. I was on the highway, messin around with a friends s2000. we both ran a bit, but i never redlines, nor went full throttle. needless to say, i still spanked him. once i hit 4th gear, engine shutoff. There was NO multiple popping.
So, i called matt at hsw and asked for his opinion. I took a plug off #1 cylinder and held it up to the block and my buddy tried crankin it over. It sparked. This means the opti is ok. Matt told me to change out the plugs. So, i put brand new tr55's in there gapped correctly.
STILL NO STARTUP.
It makes a few 'pops' and then doesnt start up. The serp belt turns over. Im thinking fuel delivery is the problem?
Any ideas???????????
Thanks in advance ... Joe
Old Apr 19, 2007 | 01:59 PM
matLT1's Avatar
Yeah, I would check for fuel and go from there. It could be your pump or even something as simple as a fuse.
IXLR894Z28's Avatar
Perhaps the fuel pump wen't bye bye. Do you hear it prime when the key is in the on position?
Old Apr 19, 2007 | 03:04 PM
2000GTP's Avatar
Put a fuel pressure gauge on it, only way of knowing if you are having fuel issues.
Old Apr 19, 2007 | 03:13 PM
just checked all the fuses .. all good
and yes, i hear the fuel pump prime
also, i doubt its the timing chain. i just got a brand new gmhp heavy duty one put in when my cam went in (2k miles ago)
Old Apr 21, 2007 | 07:56 PM
checked the timing chain .. good
gotta be the fuel pump. maybe i can get some upgraded injectors aswell and bump up the hp!
Old Apr 23, 2007 | 11:10 AM
UPDATE:
I hooked up a fuel pressure gauge to the shrader valve, and turned the key to accessory. It read perfecly at 42 psi. Is there anything else that could be the culprit besides the pump????
thanks
Old Apr 24, 2007 | 11:20 AM
Red-LT1's Avatar
Yea, the fuel filter! I thought my pump was dying cause my car was barley running. Turned out the filter was almost clogged solid lol. I didn't even suspect it cause it was maybe 9 months old. I guess I shouldn't have ran to less than a gallon of gas, but there were no stations in sight! Oh well.
Also make sure it maintains pressure under load, that's where it is going to be more likely to fail. Still, that's an odd problem to say the least.
Old Apr 24, 2007 | 02:32 PM
BIG SHAFE's Avatar
Originally Posted by emerica4601
UPDATE:
thanks
Check the pressure while cranking, to see if it dies off.
Old Apr 24, 2007 | 03:49 PM
TobyZ28's Avatar
Spark is only good if its at the right time to the right cylinder Perhaps your opti screwed up internally?
When you crank it how does it sounds? Does it sound like any cylinders are firing and it wont start or does it sounds like its just spinning completly on the starter with nada to any cylinders?
Noenav
Mar 1, 2019 07:38 AM
tds1213
Nov 27, 2014 12:55 PM
USAirman93
Nov 24, 2014 03:37 PM
Jul 4, 2005 05:00 PM
1LEThumper
Jul 14, 2003 12:45 PM
