2nd to 3rd shift problem
Old Sep 5, 2005 | 10:34 AM
BIGCOWL-IMP's Avatar
under full throttle when it shifts into 3rd it acts like it hits the rev limiter a few times and then shifts but i had ed right change the shift point and no help ??
Old Sep 5, 2005 | 12:09 PM
FastZinTennessee's Avatar
Re: 2nd to 3rd shift problem
I think that's the most common shift (2-3) to have problems with, just from how the transmission internals work. I had my car do that to me once. It just kept revving, and revving, and revving then finally hit the rev limiter in second before shifting into third.
May be a sign of some transmission problems. You might be able to correct it for now with a shift kit, unless you already have one on there.
Old Sep 5, 2005 | 12:12 PM
Cmr0z28's Avatar
Your transmission is slipping. Get it rebuilt.
Old Sep 5, 2005 | 12:15 PM
blk1994z's Avatar
i had the same problem, first it did it once in awhile, than it did it all the time. I got a good deal on another tranny and put it in, and everything worked fine than. I dont know what was causing that to happen, i took it to a couple shops and they said it should do that, nothing is wrong with it. Which obviously there is.
Old Sep 5, 2005 | 03:29 PM
Red on Red WS6's Avatar
Mine does the same thing but only when in 3rd when I leave it in Drive it will shift fine. I am sure the tranny will give out someday.
barry76lt
Events and Cruise Spots
13
Jul 21, 2015 06:17 AM
PCLZ28
Apr 29, 2015 11:56 PM
97SSdude
Dec 31, 2014 07:43 PM
Jul 4, 2005 05:00 PM
