2800 Stall
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
2800 Stall
thats what im thinkin about going with for my rebuild...
what will that do to my shift points/track times?
also for the lifespan of the rebuild
Re: 2800 Stall
get a tranny cooler and a good rebuilt and it shouldn't effect life that long. trannies die due to abuse and heat. stalls make it easy to abuse them
and create heat when they aren't locked up
tranny
i would go up on my gears i had 273s in my car and tore up two transmissions your car has a lot of torque and 700r4s cant take the strain is a long tranny mine kept twisting the clutch drum on the shaft macking hairline cracks in it and fluid would bleed off and burning up the cluchs and my car is pretty much stock i went to 373s and it runs 13.35 best on 273s 13.70 i would go with 342s if you drive it a lot
Not speaking from experience but I would think that cam with a 2800 TC and 2.73 gear would really hurt your low end. It would be interesting to try it though because you may be able to gas it off the line and not have traction problems with street tires.
Jeff D.
Jeff D.
cause my mods are small and simple... listed below... and starting from an IDLE with the 2:73's on VERY GOOD SOFT tires, deflated, with posi, i have traction problems already... i have to baby it to about 15 mph then floor it...
tranny
4L60E is the same except your passing gear is controlled by the cpu and other shift points also no tv cable i have a 93 with a 700r4 if you really want a sweet tranny bolt a turbo 400 with a gear vendor and it will be pretty much bullit proof
Nayr
Mar 3, 2023 08:34 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
