2800 Stall
Old May 30, 2003 | 06:13 AM
frmula1's Avatar
From: Somewhere between a shotgun barrel, and a blood spatter on the wall.
2800 Stall
thats what im thinkin about going with for my rebuild...
what will that do to my shift points/track times?
also for the lifespan of the rebuild
Old May 30, 2003 | 08:15 AM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
Re: 2800 Stall
nothing and shorten it
get a tranny cooler and a good rebuilt and it shouldn't effect life that long. trannies die due to abuse and heat. stalls make it easy to abuse them and create heat when they aren't locked up
Old May 30, 2003 | 08:52 AM
shox9879's Avatar
tranny
i would go up on my gears i had 273s in my car and tore up two transmissions your car has a lot of torque and 700r4s cant take the strain is a long tranny mine kept twisting the clutch drum on the shaft macking hairline cracks in it and fluid would bleed off and burning up the cluchs and my car is pretty much stock i went to 373s and it runs 13.35 best on 273s 13.70 i would go with 342s if you drive it a lot
Old May 30, 2003 | 10:11 AM
PoorMan's Avatar
Not speaking from experience but I would think that cam with a 2800 TC and 2.73 gear would really hurt your low end. It would be interesting to try it though because you may be able to gas it off the line and not have traction problems with street tires.
Jeff D.
Old May 30, 2003 | 11:05 AM
frmula1's Avatar
whew.. good thing i have a 4l60E
why do people keep saying this? is my car a freak?
cause my mods are small and simple... listed below... and starting from an IDLE with the 2:73's on VERY GOOD SOFT tires, deflated, with posi, i have traction problems already... i have to baby it to about 15 mph then floor it...
Old May 30, 2003 | 04:16 PM
shox9879's Avatar
tranny
4L60E is the same except your passing gear is controlled by the cpu and other shift points also no tv cable i have a 93 with a 700r4 if you really want a sweet tranny bolt a turbo 400 with a gear vendor and it will be pretty much bullit proof
Old May 31, 2003 | 12:04 AM
frmula1's Avatar
the 400 fits right up?
and is still electronically controlled?
how much for one?
Old May 31, 2003 | 12:27 AM
Ghettoraid's Avatar
How do you cool a manual transmission? All I've been able to find are these wierd finned reservoir expanders with heat fins on em... and not for the T56... heh
Nayr
Mar 3, 2023 08:34 PM
IndyZman
Oct 22, 2015 02:17 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
greenzee28
Sep 25, 2015 04:29 PM
damnyankee36
Sep 9, 2015 07:06 PM
