230/236 cam and 700r4 are IN!!!!!
Old May 17, 2003 | 12:49 AM
96LT14u2Nv's Avatar
Thumbs up 230/236 cam and 700r4 are IN!!!!!
it is definately a different animal. im too used to a stick.
the cam is freaking awesome and first gear is just insane on the car now. it just leaps!!!! i finally couldnt be happier.
mods done:
230/236 cam
crane gold race 1.6 RR's
LT4 springs
new opti
CSI electric H20 pump
cloyes true double roller timing chain
700r4 tranny
Coan 3200 stall converter
should be 12's for sure. and it sounds AWESOME!!!!
going to track tomorrow. i will fill u in on how it goes
Old May 17, 2003 | 02:15 AM
allmotorta's Avatar
What lift are LT4 valve springs good to? Are you sure its enough for the 230/236? Other than that, your combo sounds good, definitely in the 12's somewhere
Old May 17, 2003 | 03:43 AM
Kain's Avatar
Even on the crappiest of street tires, with a decent launch you should see high 12's.
Old May 17, 2003 | 04:43 AM
jkipp84's Avatar
Exclamation
Are you positive those are LT4 springs? Those are no where even close to being the right springs for a 230/236 with 1.6's!
Before you wind up that engine, I'd give some very, very serious thought to putting the right springs in there ASAP.
Old May 17, 2003 | 10:48 AM
bad95z28's Avatar
ditto. those springs will not support your lift. you need something good to up to .600 or so.
Old May 17, 2003 | 12:39 PM
96LT14u2Nv's Avatar
the LT4 springs are good to .525 lift and the cam is ......
Advertised Duration Int.: 282
Advertised Duration Exh.: 288
Duration @ 0.050 (I/E): 230/236
Lift, (I/E): .510/.520
Lobe Separation: 110°
RPM Range: 2200-5800
Type: Retro-Fit Hydraulic Roller
how much lift is 1.6 RR's adding to the cam?
i know it is pushing it but it shouldnt be over too much should it?
Old May 17, 2003 | 12:46 PM
jkipp84's Avatar
Your cam with 1.6's is now 544/555ish. Clearly too much for those springs.
Take the lift (we'll use 510) and divide it by 1.5. That'll give you 340. Multiply that by 1.6 and you'll get 544. That's how you calculate the difference 1.6's will make when used with a cam which lists it's lift with 1.5's.
Old May 17, 2003 | 01:04 PM
AdioSS's Avatar
West South Central Moderator
besides, the LT4 springs were designed for the LT4 and LT4 Hot cam lobes. The XE lobes are much more aggressive and will wear out a spring much quicker.
Old May 17, 2003 | 01:39 PM
NiteRider's Avatar
Yes those springs will bind. Not a good idea man, maybe pull them out and pick yourself up a set of cc-986 or cc-987 springs. But seriously pulls those springs out before you do some serious dmg to anything else.
Old May 17, 2003 | 02:06 PM
1QUIKTA's Avatar
I was thinking of a 700R4 swap also. Did you have any complications? Any special parts needed? Make sure and post those track times with the new combo. I was thinking of a XE 230/236 or a CC306 cam this winter.
Old May 18, 2003 | 08:51 PM
Dave Feerst's Avatar
My comp cams book shows the XE 230 236 cam with 490 lift
thats .523 with 1.6 what am I missing??
Old May 18, 2003 | 09:03 PM
nevermind, I found the cam you have. the peak RPM seems low. dont most guys on the board find this cam actually goes till 6100 or 6200?
jimmybandana
Mar 22, 2015 07:44 PM
Cam's maro
Jan 30, 2015 09:21 PM
CaRParts102
Dec 6, 2014 08:45 AM
slocody
Feb 10, 2003 01:04 PM
Chris Ja
Aug 1, 2002 07:30 PM
