224/230 feeling
Re: 224/230 feeling
Originally Posted by 94zgreenmachine
Get rid of those 2.73 highway gears and give the car some gear.
Re: 224/230 feeling
Originally Posted by black95z0122
where would u guys say the car starts to "wake up". Do u really need to rev it to 4000 before it kicks in? I allways heard that this cam had a nice fat powerband and would start to pull in the 3000s.
Also what do u guys have ur rev limiters set at?
http://slackercracker.com/hpt/Loadre/dyno2.jpg
I shift at 6100.
Re: 224/230 feeling
Originally Posted by Loadre
You can check out my dyno graph. Red is NA pull.
I shift at 6100.
I shift at 6100.
Does the car pull at all in the 2xxx's? Is it a dramatic loss or does it feel close to stock?
I'm 99.9% sure i'm getting one in a few weeks
Re: 224/230 feeling
Seems like ur numbers at 3600rpms are better than a car w/ headers alone and things just keep getting better up to 6000 or 6100. I would guess that the #'s in the 3000 are stock or slightly better. Sounds pretty good to me.
Re: 224/230 feeling
Re: 224/230 feeling
Between 3000-3500 is where it starts coming on. I shift at 6000. I raced a 94Z a couple of weeks ago. He had a 383 with the hotcam kit. I pulled a 1/2 car in each gear from 4500-6000. You could really feel,see the difference in the power bands.
Re: 224/230 feeling
I think it depends on the setup. I'm running a XE 224/230 with heads, 1.6rr's, 4.10's, etc., etc., etc., and mine begins to rocket away @ 2500 RPM, and it doesn't quit until about 6000 (that's where I shift at least...)
Re: 224/230 feeling
Re: 224/230 feeling
I'm running 4.10's in my 10-bolt, which are fine...but keep in mind I seldom drive it with slicks on, and I don't get on it often. Anyways, as far as head work, I just bought some GTP Stage II heads off this board. If I'm not mistaken, I believe the flow #'s were along the lines of 265 int & 190 exh...?
