224/230 Dyno Results...Your Thoughts
Got dynoed today. Have the following mods:
Comp Cam XE 224/230 Cam
Comp Cam High Tech Push Rods
Comp Cam Type "R" Lifters
GM Heavy Duty LT4 Timing Set
Comp Cams Pro-Magnum 1.6 SA Rocker Arms
Cmotorsports ex 612 Springs
Descreened MAF Sensor
Jet-Hot LT Headers
Hooker Jet-Hot coated Y-pipe
Corsa Pro-Series Cat-back
K&N Cold Air Intake
Hypertech 160 Thermostat
Meziere Electric Water Pump
PCMFORLESS Programming
Vented Opti-spark Swap
!AIR
!EGR
Holley 52mm Throttlebody
LT4 Knock Module
Taylor 8mm Spiro-Pro Wires
NGK TR55 Plugs
Manual Fan Override Switch
Auburn Pro Posi
Richmond 3.73 Gears
MSD 6AL
MSD Blaster 2 Coil
I was not allowed to lock-up my converter. On my best run the dyno messed up but I still got a print out of it. I'm thought my air/fuel was a little low so I will be called bryan from pcmforless on fixing that. I'm also getting my quicktime electric cutout and march crank and alternator pulley installed this week. What are your thought and suggestions.
-Matt
Video of my run:
Dyno Run
Jet-Hot LT Headers
K&N Cold Air Intake
!AIR
!EGR
LT4 Knock Module
NGK TR55 Plugs
Auburn Pro Posi
Richmond 3.73 Gears
MSD 6AL
MSD Blaster 2 Coil
-Matt
Video of my run:
Dyno Run
Originally posted by rob97ss
are those numbers with stock heads?
Autos tend to make less on a dyno but if you couldve locked your converted then you wouldve seen some more ponies. I will be having mine dyno tuned after the long tubes and duals go on.
that is what i would expect. i dynoed just a little higher with a little bigger cam when i was auto. do an ASP pulley and cutouts and i garuntee u will pick up 5-10 to the wheels . i wouldnt be suprised to see 340 when u get it tweaked a little more
good numbers
good numbers
I got 326/318 SAE with mid length (1¾") RK Sport headers. I guess the numbers are about right on? I thought my tq was low, but maybe it is the cam..
LimitedEd1LE
May 18, 2015 01:24 PM
