2000 plastic tank: What pump Kit to buy/racetronix 93 or 99+
Old Sep 23, 2004 | 11:01 AM
csmonte's Avatar
Question 2000 plastic tank: What pump Kit to buy/racetronix 93 or 99+
I am upgrading to the 99+ plastic gastank and while I'm doing this I am going to upgrade the fuel pump. So far people recommend the Walbro/racetronix setup.
I'm looking at the kits and they have recently upgraded to the new better fit styles.
they have two kits. the LT1 kits and the LS1 kits.
I'm curious about the wireing on the LS1 kits.
Are they the same, do I buy a LT1 Wire harness with a LS1 pump?
Do I need the wireing harness?
I am clueless on this upgrade, any replys greatly appriciated.
thanks
Old Sep 23, 2004 | 11:03 AM
Z95m6's Avatar
Re: 2000 plastic tank: What pump Kit to buy/racetronix 93 or 99+
I think the best way to get the answer you want is to email Racetronix. I'm sure they are the most qualified to answer your question.
Old Sep 23, 2004 | 12:09 PM
Racetronix's Avatar
You would need the F99+ pump assembly to fit the 2000 tank + module.
You would require a custom harness. The fuse holder and interface for the factory wiring (power trigger and level sender) would have to be LT1 based and the fuel module plug would have to be 99+ F-LS1 based.
E-mail sales@racetronix.com for lead times and pricing.
You will need to fabricate some custom plumbing to interface the module to the F-LT1 factory metal lines.
Old Sep 23, 2004 | 01:06 PM
jeremyferguson's Avatar
Would it be possible to take the whole module out of a steel tank, and use it in a plastic tank(i.e. take off the five nuts that hold the module onto the steel tank, and drop it into the plastic tank and tighten the five nuts down)?
so basically just changing tanks.....
Old Sep 23, 2004 | 01:08 PM
Racetronix's Avatar
No.
Old Sep 23, 2004 | 01:43 PM
Originally Posted by Racetronix
No.
o.k.
D1SC383LT4
Jan 1, 2016 01:56 PM
jayvar
Feb 2, 2015 10:00 PM
Deadbolt24
Jan 19, 2015 01:29 PM
ANDYZ28
Dec 29, 2014 09:13 PM
squarehead
Nov 21, 2014 08:02 PM
