200 amp powermaster alternator....need new wires?
Old Dec 21, 2005 | 07:03 PM
rawbutt's Avatar
I'm going from my stock 140 amp alternator to a Powermaster 200 amp (part# 47805). Am I ok with my stock wiring or should I get something beefier? If so, any ideas where I could get the thicker stuff ?
Thanks in advance!
Old Dec 22, 2005 | 09:43 AM
97FormulaWS-6's Avatar
Re: 200 amp powermaster alternator....need new wires?
I would suggest upping and replacing the main 3 wires... Neg to Ground, Pos to Alt, and Pos to Car.
As for where to get the wire, Knukonceptz.com has awesome deals on large gauge wire.
I'm running a large stereo system with mine, so I have 00 run for the main 3, plus the run to the amps. But for your application I'd say 4Ga should be plenty. Or for the wire and ends, check your local car stereo install shops, all of them buy the wire by the 1000' roll.
Old Dec 22, 2005 | 10:44 AM
rawbutt's Avatar
Great ideas! I didn't even think about checking with the local stereo shops. All I have as far as extra draw on my system is a mild stereo (amp and one 12" sub). I can't remember the exact power specs for the amp, but like I said, nothing radical at all. I'm torn between going back with a 140amp alternator vs. getting the Powermaster 200amp. What do you think? It's a little hard for me to justify the price tag of the 200amp with nothing that really demands it right now, but would hate to be borderline if I got more stereo or anything else later on.
Old Dec 22, 2005 | 10:59 AM
asudecat's Avatar
where are you getting the 200 amp alt?
Old Dec 22, 2005 | 11:02 AM
rawbutt's Avatar
was looking at the Powermaster 200amp at Summit (part# 47805)
Old Dec 22, 2005 | 11:29 AM
asudecat's Avatar
There is a guy on LS1tech.com that gave me a # to a shop in Kentucky that re-builds alt's and starters.
I called them and he quoted me $189 for a 200 amp alt. and $129 for him to re-build it.
I will try and find the #
Old Dec 23, 2005 | 09:15 AM
the stock alternator is a 140A... so if you're looking to upgrade, the 200A is about your only choice (With a few exceptions).
Old Dec 24, 2005 | 12:46 AM
bdc95ta's Avatar
Do some voltage drop tests and see what's up. Or you can just order these I have them on my ta and they're excellent quality.
http://innovativewiring.com/camaro/c...omepagenew.htm
-brandon
silvermansteve
Mar 4, 2015 05:02 PM
NewsBot
Jan 8, 2015 11:29 PM
97FormulaWS-6
Aug 5, 2002 05:15 AM
frs5
Jul 30, 2002 08:01 PM
Zomie
Jul 21, 2002 08:03 PM
