2 way cats
Old Jul 23, 2004 | 09:36 PM
lt4 fd's Avatar
2 way cats
Hey its my understanding 2 way cats do not need an AIR system or smog pump yada yada, I was wondering if anyone made them for us and if they do well with passing emissions?
Old Jul 24, 2004 | 04:23 PM
Re: 2 way cats
You have a "2-way cat" from the factory.... the AIR system is used only for about 3 minutes on startup to heat up the cats faster, and it connects only to the exhaust manifolds. This is unlike the earlier setups used on the 3rd Gen F-Bodys, for example, that first ran the AIR system into the exhaust manifold on startup, to heat the cats, and then switched AIR flow to a connection on the cat, in between the reduction and oxidation beds. Look under your car.... no AIR connection on the cat. yadya yada
Old Jul 25, 2004 | 12:24 AM
lt4 fd's Avatar
Re: 2 way cats
oh my missunderstanding then, thanks for clearing that up Well I was also told that the air system keeps the cats from clogging am I right to assume this is untrue as well?
n2oblkz
Oct 12, 2015 01:53 AM
football4life
Oct 4, 2015 07:48 AM
Ks0209
Oct 1, 2015 07:32 AM
Tarizza
3rd Gen / L98 Engine Tech
Sep 20, 2015 03:26 PM
Sep 11, 2015 09:44 AM
