2-Steps
Old May 25, 2006 | 02:49 PM
my94blackz's Avatar
2-Steps
How are you running yours? Where is the activation switch? How did you mount it to the clutch? What button did you use?
I tried running mine one time, I mounted the button behind the clutch but it was just ****ty. Was just curious to see what every one else was doing.
Old May 25, 2006 | 02:53 PM
1racerdude's Avatar
Re: 2-Steps
Ya put it on a button on the steering wheel along with your line lock.
Old May 25, 2006 | 05:09 PM
94 NO TOP Z's Avatar
Re: 2-Steps
I wired mine into the cruise control set button. Just hold in the middle button to engage the two-step and let go to disengage. Just tee'd a wire into a wire at the cruise contol controller under the hood. I haven't tried it at the track yet though. Only downfall I see is when I do set the the cruise or use the accel function it will turn on the two step but, I wouldn't think when I use the cruise I would be running at that high of an rpm anyway.
Old May 26, 2006 | 09:34 AM
RealQuick's Avatar
Re: 2-Steps
WHich 2 step are you guys using?
Old Jun 26, 2006 | 09:48 AM
Grims's Avatar
Re: 2-Steps
I used the one on the Mallory HiFi box. I just wired it to the button on my Hurst shifter.
detroit1994z28
May 14, 2015 12:09 AM
96LT1TX
Jan 16, 2014 10:36 AM
BLWNnSPRDZ28
Dec 7, 2009 06:58 PM
red83
Feb 3, 2008 12:32 AM
TQdrivenws6
May 11, 2007 01:07 PM
