2-steppin a 6-speed
Old Aug 10, 2003 | 02:05 PM
Kevin97ss's Avatar
2-steppin a 6-speed
Anyone use a 2-step rev limiter to launch there 6 speed? What did you use, ignition box or stand alone limiter.
Kevin
Old Aug 10, 2003 | 02:55 PM
Ws6Envy's Avatar
i personally use a 6al w/ a msd 2 step.....but a buddy of mine uses a digital 6 i believe.
i love the msd 6al w/ the msd 2-step.
Old Aug 10, 2003 | 03:39 PM
Kevin97ss's Avatar
Thanks for the reply. One more question, how did you trigger the 2-step, from the clutch or a push button by hand?
Kevin
Old Aug 10, 2003 | 03:47 PM
tryme96Z's Avatar
Good old 6AL and its built in rev limiter have worked fine for me. What do you use the step for exactly?
Old Aug 10, 2003 | 04:30 PM
Kevin97ss's Avatar
You would set the second step at the rpm you want to launch at. Example 3500rpm, trigger the two step, hold the gas pedal to the floor and the rpm's would stay there untill the trigger is released either by a switch on the clutch pedal or a push button. One less variable when trying to get a consistant 60-foot time. Once the 2nd step is deactivated the max rpm chip would come back on providing over-rev protection.
Kevin
Old Aug 10, 2003 | 06:07 PM
Ws6Envy's Avatar
i used a button on the shifter
Old Aug 10, 2003 | 07:41 PM
Kevin97ss's Avatar
Thanks Ws6Envy.
Kevin
G-BODYT56
Jan 14, 2022 11:14 PM
techstar
Aug 6, 2015 11:20 AM
82Z_ORAMAC
Nov 23, 2002 09:29 AM
Desolate_Flux
Aug 20, 2002 03:41 PM
