2 Release bearings in 10K miles?
Old Apr 22, 2003 | 09:10 AM
ASIM's Avatar
Hey guys:
I have a 95 M6 making moderate power. 14k kilometers ago, the throw out bearing broke. The tranny shop said that I had to replace it, the slave and since I'm here and the car has 89k Kils anyways, the clutch. Last week I started the car and heard a nasty metal/metal sound that went away when I release the clutch but comes back when I press down. I drove the 2 klm's home and the sound was louder the last 3/4 shifts. I called around and every one I speak to says....throw out bearing.
The car is now un-drivable and at another tranny shop.
What gives?
95 M6, 17's, lowered, Borla etc.
Old Apr 22, 2003 | 03:50 PM
Generation specific maintenance issues should be posted on the appropriate "tech" forum... in this case LT1 Tech.
moving.....
Old Apr 22, 2003 | 04:02 PM
joeSS97's Avatar
Are you one of those people that sit at a light with the car in gear and the clutch in?That will kill it pretty fast.
Old Apr 22, 2003 | 04:16 PM
95CamaroZ-28's Avatar
Not quite. That's just normal use. It may shorten the life of the clutch by a fraction, but it should wear down the disk before it wears out the throw-out bearing. My stock clutch had 130,000+ on it, with it's fair share of beating. When I felt lazy, or was going to have to sit for a while, I would sit in neutral. However, 95% of the time, I sat with it gear holding the clutch. My clutch disk was worn, but I never had any trouble out of the throw-out bearing.
I would say you ran across a pressure plate with a below par bearing in it, or the clutch was not installed properly.
BPS
9
Mar 5, 2015 10:51 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
StansZ28
Feb 19, 2015 07:39 AM
alphaauto
Jan 23, 2015 07:42 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
