2 problems... ignition and VATS
Old Oct 8, 2009 | 07:14 PM
bkpliskin's Avatar
2 problems guys... first, my ignition becomes very hard to turn when I turn the car off. I can turn the key back and shut the car down. After that I have to really wrench the thing back to get the two little lines to align and be able to take the key out of the ignition. What would cause this?
Next, I got the portion of the VATS system deleted by Bryan at PCMforless when I got my tune done but how do I get the rest of the system deactivated? I always have trouble with the SECURITY light coming on when I try to start the car and I have to wait exactly 3 minutes for the light to turn off before I get another chance to start the car. Occasionally it hits me with a double dose of 'security' and I have to wait an additional 3 minutes.
Old Oct 8, 2009 | 09:08 PM
The first problem could be your ignition switch jamming up or the linkage to it having a problem. You can take the rod loose from the switch and see if the key turns freely. That should help you isolate the problem.
The VATS issue is likely that it is not receiving the pellet info from the key. PCM reprogramming does not address this part of the VATS.
Read about the VATS and igntion switch in the How To's section on my Tech Page. Link in sig.
Jeff1904
Jun 5, 2016 05:00 PM
IndyZman
Oct 22, 2015 02:17 PM
PopoFormula
Oct 12, 2015 04:19 PM
colts0455
Oct 4, 2015 09:47 PM
colts0455
Sep 27, 2015 01:07 PM
