2 pc rear main crank
Old Jul 18, 2004 | 03:14 PM
STEELDETAILER's Avatar
I'm trying to get back into a 4th gen car, and I have a few questions about the LT1's. Can I run a 2 pc rear main crank in an LT1 block? Thanks for looking, and any help you can give me.
Old Jul 18, 2004 | 04:27 PM
Dave88LX's Avatar
Re: 2 pc rear main crank
Don't take this as a flame, but why would you want to? When a nice cast 1pc RMS crank that can supposedly hold ~600-700 hp for $230 can be had...(Scat9000)...
Old Jul 18, 2004 | 04:36 PM
96capricemgr's Avatar
I know one of the guys on the Impala board did use a 2 piece crank and an adapter, he said he would not do it again. I asume you are looking to do this based on trying to save a buck, have you considered needing an adapter and a new flywheel or flexplate, on top of the $110 or so to have the old crank cleaned up? Much of the time the cheap road costs more by the end of the project.
Old Jul 18, 2004 | 04:42 PM
Dave88LX's Avatar
Also, check the drivetrain forum, I don't know why he posted there but there's a recent thread where a guy mentions there being some kind of adapter...I asked him the same thing...
Old Jul 18, 2004 | 05:06 PM
Thanks for the info. Yes I was just trying to save a buck. I'll have to think about a cast crank. Has anyone run one, and produced alot of power. I run Pontiac engines, and we have run cast cranks, but I'd like to run a forged crank. I was wanting to build a 383 or 396 for the least amount possible.
Old Jul 18, 2004 | 06:07 PM
Dave88LX's Avatar
How much power are you looking to make? Power adder?
www.adperformance.com call him up and see what he can do for you.
Old Jul 19, 2004 | 01:01 AM
I'm not sure yet how much I want to make, but I would like to run a power adder one day.
Old Jul 19, 2004 | 02:11 AM
mrz28 73/97's Avatar
There's nothing wrong with using a 2 pc crank if you already have one because buying the adapter is cheaper than buying the 2 pc crank.
But to further answer your questions about the LT1, all Gen I sbc rotating parts will work as will oil pumps, pans 86 - up and cams for 86 - up.
Even the Gen I heads can be made to work by converting them to reverse cooling, not sure how much that costs but some members here have done it.
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
