2 part ?-Gasket Help--Noise Help---
Old Jun 8, 2006 | 08:51 PM
Lt1son's Avatar
Question 2 part ?-Gasket Help--Noise Help---
Well i blew exhaust gasket on the PS...just sum help on sum stuff i need to get outta the way to make it easier...and i have a tapping noise that comes and goes when it wants but now i think its here to stay...loud at idle..but goes away at like 2k...Im thinkin Lifter?..but then some days it will go away..its hard to tell w the exhaust leak just gettin so bad...ne1 think these to could b related?...Any help on either would be great thanks..Also if ne1 could help w... part #'s for lifter rocker arm pushrod combos that you rec. would be great thanks
Old Jun 9, 2006 | 03:21 PM
Stoopalini's Avatar
Re: 2 part ?-Gasket Help--Noise Help---
The tapping noise is probably the exhaust leak. Fix the leak 1st and see if the tapping goes away.
I don't really understand what advice you are asking for? Do you want to know what to remove to replace the gasket? If so, exactly which gasket is leaking, what kind of car do you have, and what mods have been done?
Thomas.
Old Jun 9, 2006 | 06:21 PM
Lt1son's Avatar
well its a 94 Lt1 with hooker long tubes..and its teh headergasket i blew...i cant get the two outer bolts off...alt is moved and so is air pipe...any ideas would be great thanks
HectorM52
Jul 30, 2017 11:46 AM
novaiiman
May 15, 2016 11:36 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
