2 foot of water!!!!!
Old Dec 3, 2004 | 03:58 PM
KillWhitey's Avatar
I hit a creek flowing over the road outside of houston about a week ago. It was about 2 feet deep. After about 5 miles if I gave it more than 1/4 throttle it would studder and back fire until it hit about 2500 rpm then it drove like normal. about 2 minutes later it died and would not start.
I had it towed to my dads house and got it up on jack stands and the starter housing had shattered. I replaced it and it drove like normal. When i left I got on I 10 and when it hit opperating temp it started to run like crap again. So when i got home I tore it apart and put a new opti on it. It ran the same with the same simptoms as above.
What the hell do yall think is wrong?????
Tim
Old Dec 3, 2004 | 04:14 PM
TigerWoodsJr's Avatar
Re: 2 foot of water!!!!!
some kind of sensor down there it may have killed? that sux though.
Old Dec 3, 2004 | 04:23 PM
KillWhitey's Avatar
I was told maybe the MAF but i dont know how to test that. Any suggestions?
Tim
Old Dec 3, 2004 | 04:47 PM
Heatmaker's Avatar
Advanced Member
you simply unplug the MAF sensor and see how it runs in speed density mode... (wich occurs if the MAF is unplugged)... is your SES light on?
Old Dec 3, 2004 | 05:05 PM
brendon444's Avatar
some water might have got on the coil happened to me and it ran good till it got warmed up.
Old Dec 3, 2004 | 05:12 PM
KillWhitey's Avatar
SES light is on now and it runs the same with the MAF plugged in or not. How do i check the coil?? just replcae it and see if its the problem?
Tim
Old Dec 3, 2004 | 05:37 PM
Heatmaker's Avatar
Advanced Member
If you take the coil off... you can take it to autozone and have them test it for free...
but 'm curious as to wy your started blew up on you...
Old Dec 3, 2004 | 06:45 PM
BlownF1's Avatar
Best bet is to scan the code generating the SES light...and work from there.
Old Dec 3, 2004 | 06:52 PM
KillWhitey's Avatar
Thanks for the help. I will work on it from here tomorrow
Old Dec 5, 2004 | 12:35 PM
1racerdude's Avatar
O2's?
Old Dec 5, 2004 | 10:41 PM
bowtiethunder's Avatar
same exact thing happened to me, and the starter busted on me too. One thing you might want to do is check your oil, it probably has water mixed in it. Another thing is to check your plugs too. At least you didn't have to push it out of the puddle like I did since thats were mine stalled.
G-BODYT56
Jan 14, 2022 11:14 PM
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
68camaroboltz
Oct 5, 2015 01:46 PM
colts0455
Sep 27, 2015 01:07 PM
