2 cylinders have red hot primaries...why?
Old Jun 8, 2005 | 09:16 AM
Gripenfelter's Avatar
Finished the new motor install.
My #5 and #6 cylinders had red hot primaries after 30 mins of idling at 2000 rpm.
Its a 383 btw and I have no cats.
Any ideas?
Old Jun 8, 2005 | 09:51 AM
Re: 2 cylinders have red hot primaries...why?
Just occurred to me, I forgot to tell the engine builder that these were comp R lifters.
Could an overtightened intake or exhaust valve causing a lean condition?
Old Jun 9, 2005 | 08:11 AM
Fixed it.
For anyone else having this problem, the rockers were too tight.
New engine and the engine builder tightened the rockers down to zero lash but once the engine fired up, the lifters pumped up and kept the exhaust valves open.
Resulted in a poor idle as well.
Took me 1.5 hrs to jack up the car, disconnect the alt, re-lash all the valves to finger tight, lock them, re-assemble the car and put it on the ground.
Old Jun 9, 2005 | 08:30 AM
1SlowFormula's Avatar
Glad to hear you got it fixed...
Just out of curiosity, why did you need to jack up the car to work on the vavle lash? I would think that would make it harder, or maybe it's just me, I hate reaching into the engine bay with it up on ramps...
Old Jun 9, 2005 | 08:55 AM
I had to turn the crank with a torque wrench to put every cylinder at TDC when I lashed it.
Old Jun 9, 2005 | 09:17 AM
Oh yeah I forgot about that step... I am planning on installing RR's in a few weeks so I guess I should have remebered that
Old Jun 9, 2005 | 10:02 AM
Kurt Crosbie's Avatar
Why not just set it while the engine is running? Thats how i was taught to do it.
Old Jun 9, 2005 | 10:57 AM
Kraest's Avatar
Retired
Ouch. A remote starter would work 10x faster...or unplug the coil wire and do it from inside the car.
Mike
Old Jun 9, 2005 | 11:53 AM
So many people to help me crank over the engine but no one to tell me I had to re-lash the valves lol.
Didn't occur to me at the time to disconnect the coil.
Old Jun 18, 2005 | 04:55 AM
unTAmedLS1's Avatar
were you getting any backfires out the intake and low vaccuum? See my idle is "ok" but if I blip throttle i get a backfire out intake and the motor is running lean and I have low vaccuum
Old Jun 18, 2005 | 09:29 AM
Do you still have cats?
I had none of those symptoms.
CHeck to make sure your plug wires are wired up correctly.
Critter
Jul 7, 2015 08:33 PM
Jason Short
Jan 19, 2015 06:34 PM
Collector Car
Dec 17, 2014 01:12 PM
