2 bolt to 4 bolt conversion
Old Mar 17, 2007 | 10:44 AM
Dtimekw's Avatar
Talking 2 bolt to 4 bolt conversion
I am building a 383 w/ an LE2 package and am having the block done locally. Through many problems I recently found that the block is a 2 bolt, not the 4 that I wanted. So, what is the best conversion out there? I've heard of everything from 2 bolt to stud and 4 bolt splayed. Which is the best. My intention is to put together a bullet proof bottem end. Thanks.
Lloyd, you read it right, the block isn't even together. He does have your parts list though
Old Mar 17, 2007 | 10:50 AM
LiENUS's Avatar
4 bolt splayed is very strong, but be sure your cap is a good cap, don't skimp out on your cap. A 2 bolt stud with a good billet cap will hold more than a 4 bolt splayed with a cheap cap. But a 4 bolt with a good cap will hold far more than the 2 bolt ever could.
Old Mar 17, 2007 | 11:00 AM
Kevin Blown 95 TA's Avatar
In other words, go splayed 4 bolt, and don't get Eagle (made in China) caps.
Old Mar 17, 2007 | 11:05 AM
modracr62's Avatar
The problem with 2 bolts is not an issue of anything breaking. It an issue of main cap walk. Go with the extra 2 bolts to keep that main cap still. The eagle main caps arent that bad of a peice. Tolerences on them are pretty good. Seem to hold well.
Old Mar 17, 2007 | 11:43 AM
LiENUS's Avatar
Good billet caps with good studs walk less. But of course a good 4 bolt cat (even non billet) will do better than a billet studded cap. Unless you're getting titanium billet 2bolt caps in which case its probably custom designed and ya may as well go with 4 bolt since it would cost just as much to machine.
Old Mar 17, 2007 | 11:51 AM
MachinistOne's Avatar
In a street car I have never seen the actual cap fail, that is not the issue. The advantage is clamp load, and spreading the point of register on the cap out to the pan rails, that is why you run a 4 bolt cap.
Use Pro Gram.
Old Mar 17, 2007 | 11:52 AM
LiENUS's Avatar
Use Pro Gram.
If you're using a cheap 4 bolt in a high horsepower application you will tend to flex the cap a little. Thats why I'm saying to stay away from a cheap 4 bolt. Clamping load is affected by a lot of things and stiffening what you are clamping can help some with clamping load.
Old Mar 17, 2007 | 12:00 PM
What you need in the way of main caps/bolts is a function of the HP level, and whether you are running a power adder. That's not clear from your post.
Old Mar 17, 2007 | 12:30 PM
I have never used the cheap caps, always pro gram or the ones we make.
Old Mar 17, 2007 | 12:51 PM
Who does make "cheap caps"? Pro-Gram here too.
Old Mar 17, 2007 | 12:56 PM
LiENUS's Avatar
I'm talking ebay specials.
Old Mar 17, 2007 | 01:09 PM
Dave1980's Avatar
I will chip in on this one, cause I already did my homework.
Program caps are the best.
here is what you need to know from the mouth of programs themself.
This is a response to what caps will work with LT1.
" Are you planning on using the stock dipstick? If so, then you will need a set of our SB350C12 main caps. They are a 12.5 degree main bearing cap that is designed for street and strip use where factory dipsticks are used. You can also use a set of our SB350C22's and they will also clear." If you are planning on putting a sight glass in the pan to check oil level, you can use a set of SB350CSA2’s. These are our most popular caps by far but do interfere with the dipstick. A set includes caps 2, 3 & 4. Please feel free to contact me if you have any further questions.
Then I asked.........
What is the main difference between these two cap sets? I am interested, and trying to decide the best one, for my motor. OBTW these will be good since im going to be using a stock dipstick.
Reply
The SB350C12’s have 12.5 degree splayed outer bolts, while the SB350C22’s have 22 degree splayed outer bolts. Either set will work for your application. The C12’s tend to be a little easier to install.
Then I asked......
is either one stronger than the other based on the installed angle?
Reply
Design wise, the C22’s are stronger. Real world applications though show that something else will fail before either style of main caps.
After all of this I went with the 22 degree splayed.FTW
Old Mar 17, 2007 | 01:37 PM
I used the Pro-Grams as well but the shop got me the regular SBC ones which caused dip stick issues, instead of the ones designed for a pass side dip stick.
Old Mar 17, 2007 | 01:47 PM
Boostwhat's Avatar
How could I get in contact with ProGram? Anyone have their number handy? Derek
Old Mar 17, 2007 | 02:27 PM
Dave1980's Avatar
Dan Anderson
General Manager
Pro-Gram Engineering
(330) 745-1004
