2.73's
If they are stock, it could be a problem, not necessarily THE problem. Most people don't change spark plugs EVER. But check plugs, wires, opti, O2 sensors, fuel filter, oil filter (ya never know), etc, etc. Basically anything that could go bad. If the owner before didn't take care of it you never know what all could be wrong.
With 100k miles on it, it's certainly in need of plugs and could probably use some wires too.
There are TONS of things that could cause slow times.
If your PCM is picking up on knock, then it's pulling timing (sometimes can be HUGE amounts of timing), causing slow times.
Your coil might be getting weak.
The opti might be having problems.
Could be some slippage in the transmission as well.
The best way to go is to put new plugs in it, if that doesn't help, then scan it and see what's going on. Once you've scanned it, then you should be able to make a logical decision on where to go next.
well i got the car about a month ago and i ran a 15.1 and 0-60' times were horrible like 2.3's but it will move on the interstate i have replaced oil, oil filter cleaned air filter (k&n) replaced diff fluid trans fluid radiator fluid and i had the cats cut it has helped a little bit but i dont think its runnign 14.00's any sugestions
i live in mississippi it was about 70 degrees that night and all my friends were running better than ever one has a 94z28 a4 with cat back cai and was running 13.8's guy witha 2002 gt was running 14.2's and 14.1's all night
i changed my plugs/wires, filters, fluids, ect. immediately after buying the car so i never got to run it at the track before a tune up.
with 60's like that, i'm willing to bet you've got some sort of an ignition system defect.
DETROIT_AREA_00_SS
Nov 5, 2002 12:31 PM
95LT1Z28
Sep 5, 2002 11:12 AM
94REDSTALLIONZ
Jul 8, 2002 07:56 AM
