2.02 1.60 valves in lt1 heads?
Old Aug 11, 2005 | 07:38 PM
Fbody1's Avatar
can you put2.02 /1.60 valves in the lt1 heads, I thought that i seen somewhere that the combustion chambers were too small or something?
Old Aug 11, 2005 | 10:26 PM
BlackScreaminMachine's Avatar
Re: 2.02 1.60 valves in lt1 heads?
Talk to Lloyd Elliot, but i beleive you can do 2.02
Old Aug 11, 2005 | 10:40 PM
Kory 88 Iroc Lt-1's Avatar
I've got a set of ported stock castings in my garage with 2.02 and 1.60 valves in them.
Kory
Old Aug 12, 2005 | 06:15 AM
mohawkmike's Avatar
I built a set for my engine. I had to put larger seats in and blend everything to the larger valves/seats. Ill know if it was all worth it when I put a good tune-up on this thing.
Old Aug 12, 2005 | 08:03 AM
madwolf's Avatar
Lloyd can do 2.05 with extra machining and a bit more $.
Old Aug 12, 2005 | 09:38 AM
blackztpi's Avatar
2.02/1.60's will not fit in stock valve seats. you will have to get larger ones put in. 2.0/1.56 is the max on stock vlave seats i believe
Old Aug 12, 2005 | 09:44 AM
Paul N's Avatar
The money spent vs the power gained is a waste for sure. After the seats and valves are upsized, its the port work done after, that will make the gains you see. I would just stick to the stock size and spend my money on a great port job and get the results that way.
My .02
oldschool
Feb 9, 2016 09:21 PM
MadMav
Feb 6, 2015 11:02 PM
Jazsun
Dec 29, 2014 12:14 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
