An opti Question...YAY
Old Aug 12, 2005 | 09:08 AM
1996z28m6's Avatar
After taking the opti out of its cubby hole do you have to replace any seals in or around the opti? (I know about the waterpump gaskets) Cause ive done it 2 times so far and ive got an oil leak that just wont go away.
Old Aug 12, 2005 | 10:05 AM
Re: An opti Question...YAY
The only oil control seal related directly to the opti is the one in the timing cover. I would replace it while the opti is out. There are two o-rings on the opti drive shaft that you might want to replace. They are not oil seals, but their purpose seems to be to stabilize the shaft.
You might also want to consider changing the water pump drive seal. It seems to be prone to leak lots of oil.
Formula Steve
Sep 19, 2023 08:31 AM
94Maroz28
Oct 27, 2015 04:38 PM
Ks0209
Oct 1, 2015 07:32 AM
colts0455
Sep 27, 2015 01:07 PM
jayblev95
Sep 26, 2015 09:44 PM
