1st prob w/ the SS
Old Dec 5, 2003 | 03:40 PM
cctp97's Avatar
1st prob w/ the SS
Hey everyone, found this board recently and this is my first post.
I got my 1st f-body this summer, a '97 SS which was completely stock, just 19,000 on the tach. Couple weeks ago put a Trick flow elbow on and couple days ago did the TB bypass and threw on a Holley powershot filter. Today I notice the service engine soon light come on and I don't know why; I mean engine is all tuned up. Only thing I can think of is that the hood came down on top of the MAF when I closed it after putting on the aluminum elbow which raised the thing a bit. Also noticed there is no seal underneath the hood scoop and that the air box is a little warped.
Any feedback on this guys? Appreciate it.
Old Dec 5, 2003 | 03:46 PM
J's 82's Avatar
recheck all your connections.. see if you can't get things to fit a bit better, tweak time is time well spent..
then pull the ecm fuse or the battery cable to reset the computer.. turn it on and see if the code comes back..
Old Dec 5, 2003 | 04:26 PM
joeSS97's Avatar
the best way to find out what is wrong is to get it scanned.Try Autozone.One thing to check-make sure the intake elbow is on the throttle body all the way.Very easy to get it wrong.Check the underside of it.
Old Dec 5, 2003 | 06:56 PM
cctp97's Avatar
Thumbs up
Good stuff, all I had to do was disconnect the battery cables and that took care of the problem. Don't know how it worked, but it did. Thanks for the help.
2QUIK6
Sep 17, 2016 02:31 PM
93 RedBird
Nov 15, 2015 08:24 AM
ZXXVIII
Sep 1, 2015 10:13 PM
War Engine
Aug 21, 2015 05:28 AM
Boss002
Jul 9, 2015 03:33 PM
