1st gear block
Old Feb 11, 2003 | 08:31 PM
darkoverlift's Avatar
1st gear block
I have a 97 with the 2.73 rear and a 2,d,od setup.. So I adjust that so I know have 1,2,d,od... Why do people do it... I though you should just leave it in d and slam the gas at the strip....
Old Feb 11, 2003 | 09:14 PM
eyeoutthere's Avatar
Re: 1st gear block
Putting it in first won’t do anything for you at the track. At full throttle, it will shift at about the same point no matter what.
You only need to put it in 1st if you want to keep the car from shifting out of 1st during part throttle. Like if you are towing something (heaven forbid), launching from a slow roll, climbing a hill, or trying to save your brakes. Regardless, a properly working A4 will put you in the right gear by itself (Most of the time).
Old Feb 11, 2003 | 10:21 PM
coxz28's Avatar
It comes in handy if you just want to go out and have fun too.
Jul 4, 2005 05:00 PM
MustangEater82
19
Sep 3, 2002 02:09 PM
simple
Aug 2, 2002 03:30 PM
