1st DYNO 253.9hp/310.5tq
Old Dec 17, 2003 | 05:03 PM
allamerican29's Avatar
253.9 hp at 4600rpm and 310.5 tq at 3200rpm
the graph broke up after 5k really bad.
I think it may be ignition related but i wanted to get some opinions. what rpm are most lt1's peak hp and tq.
My car has been a little rough at part throttle. thanks for any help
Old Dec 17, 2003 | 05:20 PM
LT4Firehawk's Avatar
can you post a link to the graph? Or email it to me and I'll post it for you. Without seeing it, it's hard to say what's going on, but usually if it starts breaking up after 5K you could either have ignition problems (wires, plugs or opti), or you could be getting knock retard (possibly false). With it being rough at part throttle, my bet would be ignition problems. What is your mileage, and when were the plugs/wires last changed?
Old Dec 18, 2003 | 12:03 AM
I will hook my scanner up tomorrow and try to send them to you.
my car has 100k. the plugs and wires were changed last May.
autolite 106 & taylor wires
also my car was running 215 degrees on the dyno/it runs 170 on the street as long as i am moving. need a switch or programming.
i also have l the lt4 knock module
Old Dec 18, 2003 | 04:37 PM
BUBBA's Avatar
Ported MAF, perhaps?
Old Dec 22, 2003 | 08:56 PM
i have had a problem with oxygen sensers dying on me. it has been a week and my car has developed a bad miss though out all rpms. i have a feeling its the opti but why would i have such a problem with the sensers.
Old Dec 22, 2003 | 08:59 PM
NewbieWar's Avatar
with bad sensors the cat usually will follow...
and the cat u will feel in all rpm ranges... perhaps u should look into this...
Old Dec 22, 2003 | 09:09 PM
Antz97ZNJ's Avatar
looks about right,all ya really have is a catback powerwise
Old Dec 22, 2003 | 09:41 PM
canbaufo's Avatar
Mine was breaking up above 5K and it turned out to be valve float. Very possible with so many miles in a case like yours. Stock valvesprings are a little weak even when new.
Old Dec 29, 2003 | 12:28 AM
I don't have a cat but i am definite that it is ignition related. with the sensors i didn't miss at wot. now it misses all the time. I am fixing to do headers and cam so I will just do the whole works i guess
Old Dec 29, 2003 | 12:57 AM
QCKZ28's Avatar
those numbers sound about right for a A4.
my guess would be optispark.
and get rid of that cat if you can. its probably clogged after 100,000 miles
jesse
93 RedBird
Nov 15, 2015 08:24 AM
fift5
11
Oct 1, 2015 10:31 AM
Daluchman1974
Sep 11, 2015 06:12 AM
tdigger9899
Sep 7, 2015 10:56 AM
Boss002
Jul 9, 2015 03:33 PM
