1ft long piece of wire - 200$????
Old May 29, 2004 | 06:11 PM
TobyZ28's Avatar
I need a bit of help here, I'm trying to replace the little wire which goes from my optispark to the electrical harness (which connects it to the computer).
I've noticed mines not working quite right, I sprayed some carb cleaner on it by accident (was looking for vaccum leaks nearby) and the engine stumbled a bit when it hit the connector, so basically I want to replace it. I'm quite sure it was the connector, it looked kinda grungy and ready to fall apart anyways.
I called up two seperate GM places and they said the part is 200$ cdn!!
What the hell? Shouldn't it be around 10-20$ or so? Thats insane... I was looking at shoeboxes page for the p/n but couldn't find it, maybe someone else can help me out? I thought I was really clear about what I was describing, and the parts people were kinda confused as to why its 200$.
The cables about 1 ft long and consists of only 4 wires with a connector on each side (one going to the opti one going to the wire harness...
It would be even better if i can find the names of all the connectors so i could maybe make it myself? I'm no electrician though...
Old May 29, 2004 | 06:15 PM
v7guy's Avatar
you really do have to spend that if you want a new one, GM partsdirect had the best deal, you might be able to get a used one on the board, I tried for about a month with no luck though. I also tried finding the connectors, but to no avail either, ended up having to buy a new one OUCH! If you have the right connectors already I would just run new wiring through them, it's not hard to rewire the plugs, just a bit time consuming
Old May 29, 2004 | 06:25 PM
TobyZ28's Avatar
Thats insane... surely someone else must have redone the wiring for this? Or replace the part.. it looks like something which would need replacing after a while on a lot of cars..
Old May 29, 2004 | 07:01 PM
96capricemgr's Avatar
I priced one once and at least for the Caprice(don't see why it would be different) it was $75 if you called a freindly dealer that will sell at cost +10%
Old May 30, 2004 | 07:15 PM
CAsnksknr's Avatar
Hey there,
My advice, make your own. Get the applicable connectors and color wires and hook it up. The Weatherpak connectors are very easy to use. Hope this helps.
Michael
Old May 30, 2004 | 07:31 PM
Mtrhds94Z's Avatar
Try Jason Cromer..
Still pricey probably[50-65?] but NOT 200!..
95-7 PM p/n 12130319
Old May 30, 2004 | 07:32 PM
Mystic95Z's Avatar
Have you tried Jason Cromer at Sam Taylor Buick/Cadillac yet?? He usually has the best price on GM parts. You can find thier number on thier website, just be sure to ask for Jason or you wont get the good prices.
-Tony
Old May 30, 2004 | 07:34 PM
bunker's Avatar
sometimes when they look up a part under F-bodies they get different part numbers for same part, its really weird, a 96 harness is the same, might be different part number. I know that intake gaskets when I called where cheaper for a 96 Caprice then a 95 Trans AM event hough they are the same.
Old May 30, 2004 | 09:27 PM
Dave Feerst's Avatar
I bought mine from GM parts direct last year. $ 55ish.
Old May 30, 2004 | 09:45 PM
curly's Avatar
Would Painless Wiring possibly have one? I know they are big into wiring systems for all cars.... may be worth a try.
Old May 31, 2004 | 10:56 PM
Tofus 93Z28's Avatar
1 word
Dal
try him
18003629494
18774485451
ur welcome...tell him your from camaroz28.com
Old Jun 7, 2004 | 10:29 AM
mkent's Avatar
does anybody know the part numbers for this wire? and/or a part number for just the connectors on both ends?
my little brother just bought a 95 formula and I believe this is the origin of his ignition problems.
Old Jun 7, 2004 | 10:42 AM
JOE96Z28SS's Avatar
GM weatherPak Connectors are EASY to repair, even if you Solder the wires to the old terminals, NO way I'd spend more than 10 dollars to fix that. hell, I'll rebuild the connector for FREE just on general principal because that's a F*&^kin Rip off
Old Jun 7, 2004 | 11:54 AM
TobyZ28's Avatar
Thank you Joe thats EXACTLY how I feel about these wires! If anyone can get the names/part #'s of the connectors so I can rebuild these things I'll get 10 or so and sell them at cost for anyone on the board. This 4 pronged wire costs more than the new window motor I just bought. My god...
But for now I'm just going to take off the old one and fix it. It looks pretty gibbled up though, I'm afraid of cracking it when pulling it out :/
Old Jun 7, 2004 | 12:05 PM
TobyZ28's Avatar
http://www.diy-efi.org/gmecm/faq/gm_connectors.html
Heres some info on GM wire connectors
EDIT: Some of the Links from the page don't work... others do... Heres another one:
http://www.powerandsignal.com/docs/P...data_sheet.pdf
Fatdog2
Feb 13, 2015 08:19 PM
Britbilly
Jan 7, 2015 08:49 PM
Dec 4, 2014 11:56 AM
Brett 91 RS LT1
Mar 12, 2003 10:02 PM
