1997 Trans Am Lt1 engine prob pls help
Old May 17, 2006 | 01:14 AM
theangel's Avatar
Was driving, punched it, motor went out, had it towed to my buddies shop, he tested optispark and fuel pump, they were fine, plugged the computer in no issues, however theres not enough compression for the engine to run what could be the problem. ALL HELP is appreciated.
Old May 17, 2006 | 01:47 AM
JimboManJones's Avatar
Re: 1997 Trans Am Lt1 engine prob pls help
Blown head gasket, broken/worn rings, to name a few possibilities, no compression is bad, and will most likely mean a decent amount of work to get it fixed, good luck man.
Old May 17, 2006 | 01:49 AM
theangel's Avatar
Thanks Jimbo really appreciate it, any other feedback is also appreciated.
oldschool
Feb 9, 2016 09:21 PM
97z28k&N
Jan 9, 2015 04:58 AM
siguy
Nov 27, 2014 10:07 AM
