1996 z28 throwing po300 and service engine soon blinking
Old Mar 23, 2014 | 12:16 PM
#1chevyfan's Avatar
So far ive changed plugs ,cleaned maf and throttle body,and changed duel pump.so is my next part the opti? If so what one should i buy and how do i change. Also which water pump? Im thinking acdelco for everything
Old Mar 23, 2014 | 12:28 PM
4th Gen 4 Life's Avatar
Re: 1996 z28 throwing po300 and service engine soon blinking
What are the symptoms of the car? What is it doing besides throwing codes and ses?
Brian
94 Z28 4l60e. Reworked heads ported and polished. Cam 3" catback flowmasters. And common bolt ons.
Any help or advice i give is my 2 cents and is based on my experience with the F-Bodies. As always seek professional help for certain problems.
Old Mar 23, 2014 | 12:50 PM
#1chevyfan's Avatar
Its idiling really ruff loss of powere aswell
Old Mar 23, 2014 | 01:19 PM
moparman's Avatar
The ol' P0300. Random, multiple cylinder misfires. You've changed the plugs, how about the wires?
Old Mar 23, 2014 | 01:49 PM
GaryDoug's Avatar
Prominent Member
By the way, the blinking SES lamp means the misfire was severe and often enough to possibly damage the catalytic converter(s). I would try to get this fixed soon, unless you have no CATS installed.
I would also try to use a scantool that can narrow down the misfires to particular cylinder(s). A Tech2 can do that as can some others. Also, my free OBD2 scan app can show the misfires by cylinder: Free OBD2 scanner software - Firebird Nation
Old Mar 23, 2014 | 01:50 PM
#1chevyfan's Avatar
Wires are 8000 miles on them inspected them looked fine also started it up at night and no sparks
Old Mar 23, 2014 | 01:53 PM
#1chevyfan's Avatar
Can i run without cats ? I will get ridd of if possible
Old Mar 23, 2014 | 08:46 PM
Did you check the fuel pressure after changing the pump? Did you check the fuel pressure regulator?
Jan 5, 2015 07:14 PM
NorthPoleDev
Dec 31, 2014 03:20 PM
Jazsun
Dec 29, 2014 12:14 PM
mspennyhughes
Nov 28, 2014 03:22 PM
siguy
Nov 27, 2014 10:07 AM
