1996 Lt1 wont start
Old Jun 13, 2013 | 05:02 PM
JDurick's Avatar
Question 1996 Lt1 wont start
Trying to troubleshoot my 1996 Z28. When I turn on the ignition I hear a click, but nothing that sounds like a fuel pump. The car has been sitting for a while, and I have not driven an Lt1 in sometime either. When I turn the ignition off, I think I am hearing the air pump for a second. The car will crank, but not fire. Just trying to figure out if it is an ignition or fuel pump issue. Mostly stock SS with a 6spd. Thank you.
Old Jun 13, 2013 | 06:31 PM
moparman's Avatar
Re: 1996 Lt1 wont start
The usual answer: check the fuel pressure.
Old Jun 13, 2013 | 06:53 PM
slick1hunting's Avatar
^^^^ yep check the pressure but also a couple other things you can do. Check the pcm ign fuse and the pcm batt fuse. You can also use a jumper wire and use the fuel pump prime connector to see it pump turns on that way.
Posted from Camaroz28.com App for Android
Old Jun 13, 2013 | 07:23 PM
my94blackz's Avatar
If you think its fuel slap a gage on it.
If you dont have a gage pull the IAC and give it a snort of either/brake clean whatevaer is flamable while some one spins it over. If it fires then you deff. have a fuel issue.
Old Jun 13, 2013 | 09:57 PM
JDurick's Avatar
Thumbs up Re: 1996 Lt1 wont start
Thanks guys. I know to throw a gauge on is the best thing to do. I didn't have one available and the car is out of state. I just had a short time to look at it today. I will have to try and trouble shoot it more next time I am in town. I was hoping for a quick and easy check. Thanks for the info.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
oldschool
Feb 9, 2016 09:21 PM
globalprojeff
Dec 6, 2014 04:18 PM
globalprojeff
Wheels and Tires
Dec 6, 2014 04:09 PM
siguy
Nov 27, 2014 10:07 AM
