1996 lt1 missfire on #1 and#2 bad
Hi! I am new to this but am in need of some help. I have a 96 Z-28 and just installed LT4 heads, intake, and hot cam. The car is misssing at low rpms and idel. Mainly it just shows on cylinders 1 and 2 the worst. But sometimes it will show very little on the others. I have new plugs, wires, and opti. I have looked for a vacumme leak but have yet found one. The car also dosn't feel like it has the power it is supposed to. If anyone has any ideas let me know. Thanks alot!
Yes I sent the computer off to PCM forless and had it programmed. I have also noticed it to run real lean around 2000 rpms. At other rpms it don't. I am runing about 58lbs of fuel pressure on 30lb injectors. Do you think I might have a vacumme leak towards the front?
I didn't tell him that. I have an adjustable reg and didn't really know what fuel pressure I would run. I still haven't really decided. But I did tell him I was running 30lb injectors. Anybody have anymore ideas?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
oldschool
Feb 9, 2016 09:21 PM
Jan 5, 2015 07:14 PM
