1995 Z28 overheating
Old Oct 20, 2011 | 09:32 AM
eiddoz28's Avatar
When It first started, I noticed coolant leaking from waterpump. I replaced water pump, thermostat, coolant temp sensor and radiator cap, still overheated. Bleed cooling system of air, car ran fine for 2 days. Now when it overheats no heat in the car. Something is blocking coolnat flow. Will radiator flush be enough to unblock flow, or do I look for another problem maybe heatercore? I do have heat when it is running normal, just no heat whhen it overheats.
Old Oct 20, 2011 | 09:40 AM
Sparkz28ss's Avatar
Re: 1995 Z28 overheating
Try bypassing the heater core.... If there is no heat coming out of the vents and there is water in the system the it's possibly a blocked core
Old Oct 20, 2011 | 10:14 AM
eiddoz28's Avatar
will radiator flush unblock heatercore( considering core is still in good condition) And how do you bypass heatercore?
Old Oct 20, 2011 | 12:17 PM
Did you buy the correct, LT1 thermostat?
Old Oct 20, 2011 | 12:27 PM
eiddoz28's Avatar
I believe so picked one up from Autozone part number 616375. prior to today tueday it would heat up then cool down, heat up then cool down. Yesterday it ran perfect from home to work and back 32 miles round trip. ran some errands last night it started heating up and cooling down.Got in it thios morning it did the same ran steady a few minutes then heated up cooled down. Which leads me to belive there is something restricting the coolant flow, almost like some kind of blockage. I'm hoping a radiator flushing can flush blockage out, otherwise have to put in shop. Radiator flushing flushes heater core out too, right?
Old Oct 20, 2011 | 12:31 PM
On search, that part # defaults to 4218:
http://www.autozone.com/autozone/par...ntifier=616375
....which appears to be the same at the one shown here:
http://shbox.com/1/tstat.jpg
If that's what it looks like, its the correct one.
Flushing the radiator will probably not clear the heater core. You take the heater hoses off at the water pump and run a flush directly through the core. But you indicated you have heat when its "running normal" and not overheating, so the core doesn't sound like its plugged.
How about the cap - 18psi?
Old Oct 20, 2011 | 01:07 PM
eiddoz28's Avatar
Replaced radiator cap with equivilent 18lb cap
Old Oct 20, 2011 | 01:09 PM
eiddoz28's Avatar
could radiator be plugged up? or air in the cooling system? I tried several times to bleed air out of sytem.
Old Oct 20, 2011 | 09:05 PM
jonesz28's Avatar
R the fans turning on at correct temp or even at all? i had a electrical issue once re: a bad fan relay, doesnt quite sound like thats the issue wit ur car but just suggestion
Old Oct 20, 2011 | 10:54 PM
eiddoz28's Avatar
yes, fans are running
Old Oct 21, 2011 | 12:26 AM
Lilatlboy6969's Avatar
i have a issue sorta like yours. except my heat blows... luke warm even if the car is cold or hot... its not much different than a/c tempatures lol. last year i flushed out my heater core a couple of times and black crusties were all in the coolant that i used to flush it out with.. the tech at work told me it was called back flushing the heater core... but it worked pretty good afterwards for a month or 2 then slowly starting getting bad again.. im thinking about completely replacing all the hoses since a few of em are in bad condition and replacing the heater core as well
ps. someone has also told me it could be a problem with the a/c or heater controls on the inside of the car.. said something about some doors inside might be getting stuck
Old Oct 21, 2011 | 08:48 AM
eidoz28:
Does it over heat primarily at freeway speeds?
Old Oct 23, 2011 | 10:02 AM
eiddoz28's Avatar
It was overheating under all driving conditions. I let the car sit all day Friday. Then I started it up and burped the system again (took off radiator cap, started car till it was up to operating temp, when thermostat opened and coolant level in radiator dropped added more coolant, then put radiator cap back on, and then turned car off, let it sit for an hour then repeated Did this 3 time, twice Friday and once yesterday), It looks like I did it right this time, Drove the car all day yesterday, did not overheat. Drove it a bit this morning did not overheat, no signs of coolant mixed in the oil or white residue on engine. Will drive it and see what happens.
Old Oct 24, 2011 | 04:09 PM
eiddoz28's Avatar
Finally took into a shop, head gasket or blown head anywhere from $1000 to $1800 to repair. Not to surprised after 175000+ miles.
Old Nov 3, 2011 | 04:30 PM
JackBlack95's Avatar
Have you been driving my car? LOL I have the identical problem......
