1995 z28 engine swap to 1980 K10
Old Dec 29, 2022 | 10:37 AM
3600-Z28-K10's Avatar
First post, so keep the sarcasm to a maximum...
I have a trashed 1995 Z28 with a low mileage crate engine that I am considering swapping the engine (maybe trans?) into my 1980 K10 project truck. Does that sound reasonably doable and/or cost effective? Any suggestions or pointers if so?
Old Jan 3, 2023 | 04:04 PM
Chimera96's Avatar
Re: 1995 z28 engine swap to 1980 K10
if you intend keeping the FI, Opti of the donor LT1 than you will need to use the donor wiring harness and PCM
Or convert the LT1 to a carb motor. GMPP makes the carb intake & Opti block off plate with timing pointer so conventional distributor is used
Crandall
Dec 17, 2017 09:13 PM
4586
Jun 10, 2013 11:48 AM
one eyed willy
Oct 7, 2007 07:58 AM
TomH
Jul 13, 2004 07:31 PM
bowties
Nov 29, 2003 12:28 AM
