1995 Z28 Coil and Coil Wire...
Old May 9, 2003 | 09:27 AM
TDog's Avatar
Ok Everyone...
I've got another question or two...
I've called around looking for an Ignition Coil and Coil Wire for my '95 Z and I've gotten several different manufacturers and prices...
I've seen the following...
Coil -- Wells for $14.99, Borg Warner for $53.80, AC Delco for $55.27, and even Holley for $65
I guess my question is...Has anyone ever bought a Well Coil is it any less reliable than the AC DELCO? Which would you buy?
Thanks,
TIM
Old May 9, 2003 | 09:53 AM
The Delco coil should not be that high. It's only $34 at Advance Auto. You might consider an MSD or similar that is ~$45.
Wells is just a standard replacement brand.
Old May 9, 2003 | 09:55 AM
93zder's Avatar
Are the aftermarket one's like MSD better that the AC Delco? Do they offer more performance on a basically stock engine?
Old May 9, 2003 | 10:00 AM
Probably not that you could tell, but I know the MSD coil has lower resistance wiring than my stock coil. It should put out more voltage.
Old May 9, 2003 | 11:04 AM
93zder's Avatar
One more question, is it possible to buy a coil wire on it's own? i am thinking of changing mine every year.
Old May 9, 2003 | 11:51 AM
You can buy individual wires at the dealer, but they are pricey.
Garcia5
Jul 7, 2022 06:51 PM
calaban
May 18, 2020 06:43 PM
Jan 5, 2015 07:14 PM
MJ_Z28
Aug 7, 2002 07:15 PM
