1995 LT1 proper cam pin length ????
Old May 29, 2007 | 10:39 AM
EnerjetF67's Avatar
Can anyone tell me the proper cam pin length for a 1995 LT1 ?
My 383 has the GMPP hotcam and has ruined the Opti bearing on my original opti as well as the bushing on my brand-new Accel opti (only got to put 3000 miles on it). Naturally this is not condusive for steady timing.
Does the cam pin length have anything to do with this ???
My mechanic (whom I definitely trust) that has installed both on my engine and he says he noticed no apparent problems installing them.
Old May 29, 2007 | 12:57 PM
Yes, too long a dowel pin will damage the Opti.
Check Shoebox's cam install page:
http://shbox.com/ci/cam_install.html
Old May 29, 2007 | 01:02 PM
Don 97 SS's Avatar
Yes, it definitely could have been the culprit. I am sure many optis lived a short life before this problem was well known.
Here is what DynSpark has to say about it:
http://www.dynaspark.net/support/Dynaspark_GEN_II.pdf
Old May 29, 2007 | 04:10 PM
Chris95LT1's Avatar
.685 Max i believe. Shoebox said his was .650. Easier just to test fit the opti with modeling clay or playdough.
Old May 29, 2007 | 06:33 PM
sam pace's Avatar
it is 21/32" 32nd over 5/8"
Old May 30, 2007 | 03:43 PM
EnerjetF67's Avatar
My pin length is approximately .640 as measured by a dial indicator.
This should not cause any Opti bearing damage, correct ?
Old May 30, 2007 | 07:26 PM
IMHO, you should be ok.
calaban
May 18, 2020 06:43 PM
Jan 3, 2015 07:22 PM
joe777107
Dec 1, 2014 09:32 AM
