1994 Z28...no spark...just died..help!
Old Mar 30, 2004 | 09:45 PM
  #16
ibanez6rg's Avatar
Originally posted by shoebox
1994-1995 Ignition control module
ACDelco #D1986A
GM p/n 10483139
Now that price is a little more suitable.
Old Mar 31, 2004 | 04:06 PM
  #17
Bad64chevelle's Avatar
Thumbs up
Thanks to everyone ...put a new ICM in, and the thing fired right over THANKS....but....i now have a MSD Blaster coil in there, and am having a problem with the car running hot...it has ALWAYS gotten hot when sitting in traffic, it never boiled over, but the temp was up there, now it gets hot just waiting for the light to turn green. Thermo (OEM 180) is new (within 2 months) and that never solved my problem before. I noticed taht my primary fan isnt working, the temp soars right over 225 and i turn the ac on to get the second fan to come on...any ideas? I switched the relays and the same thing happened. I will post this in another section, but i will still check this...thanks!
Jon
Old Mar 31, 2004 | 05:39 PM
  #18
HBHRacing's Avatar
glad you got it fixed.
as for the heating, are you sure it is the corect LT1 thermo?
I asume you bled the system correctly? do both fans come on with the ac?
Primary fan control comes from the coolant temp sensor on the water pump. if it;s out of calibration it can be reading lower then the acual temp and by the time it tells the computer to turn the fans on it could already be too hot.
Old Mar 31, 2004 | 05:53 PM
  #19
OK so i just went outside...in the rain just to see what happened if i just let it run...so i messed around for a while adjusting headlights, and waited and waited as the temp went up (VERY SLOWLY now) the temp hit 235 and the fan went on...is this OK? what is the normal temp for the fan to come on? I havent gotten a chance to drive it because its raining tonight, but maybe tomorrow...thanks!
Jon
Old Mar 31, 2004 | 07:00 PM
  #20
HBHRacing's Avatar
thats pretty much right. They come on rather late. this is why a lot of us run 160 thermos and a manual or programed fan switch
PopoFormula
Oct 12, 2015 04:19 PM
Formula Steve
Sep 19, 2015 08:48 PM
scottcba1
Sep 8, 2015 09:52 AM
95_lt1_z28
Aug 30, 2015 06:17 PM
WPHIG2
Aug 27, 2015 06:37 AM
