1994 z28 lt1 engine sucks air inlet hose
Old Aug 20, 2015 | 03:24 PM
dkred94z's Avatar
my 1994 z28 had some bad fuel issues that I think got aired out so when checking it out I had it reved to about 2500 rpm and my son was looking under the hood and noticed when I goosed it a little the air hose that goes into the tb closed like you put your fist around it cutting down on the air intake. I have had it about 3 weeks and runs good the air filter is new,( I checked it when I bought it) it has the stock air clearner on it. it does have a high lift cam in it. would it cause it to need that mush more air? is it time for a cold air type set up? thanks in advance for your help
Old Aug 20, 2015 | 04:17 PM
Re: 1994 z28 lt1 engine sucks air inlet hose
If the inlet was severely clogged, it might do that. Pretty unusual.
Old Aug 20, 2015 | 08:18 PM
Are you using the stock ribbed 90-deg elbow from the MAF sensor to the throttle body? Did you check for something blocking the screen on the inlet side of the MAF sensor.
Old Aug 21, 2015 | 12:54 PM
dkred94z's Avatar
it is the stock setup that comes on the car I think... I will check the screen in a little while. sorry it takes me a while to answer long hours at work thanks alot
Old Sep 22, 2015 | 11:24 AM
dkred94z's Avatar
sorry it took a while to get back to yall. I had lightning hit my house and ruined my electronic gadgets in the house so it took a while to get everything fixed....I went ahead and took everything apart and found nothing to stop the airflow so I went ahead and swaped the air box and filter to a fresh air type. seems ok now thanks again
Noenav
Mar 1, 2019 07:38 AM
oldschool
Feb 9, 2016 09:21 PM
thenewkid
Nov 27, 2014 09:41 AM
NED4SPD
Sep 16, 2002 10:45 PM
94z28jbw
Sep 8, 2002 03:22 PM
