1994 z28 camaro with lt1 engine
Old Sep 6, 2019 | 11:36 AM
jarios_'s Avatar
I recently did an overhaul of my lt1 engine and was wondering, since I am at the finishing steps, do i have to find tdc to be able to set the valve lash, or can I just go ahead and set it as is? I have already timed the engine, however the timing was displaced some after I put in the rockers and push rods. Was also wondering if that might affect it adversely in some way. Help haha please. I also had to have ot bored .020 over spec to get rid of some rust issues. Dont know if I'd need to tune it or if that's even possible. EDIT - it has a roller cam with lifters. 'Hydraulic lifters'.
Old Sep 6, 2019 | 04:03 PM
Re: 1994 z28 camaro with lt1 engine
Guide to setting valve lash on an LT1 from Shoebox:
4th Gen LT1 F-body Tech Articles
How did you “time the engine”? Do you mean you set it at TDC on #1?
The overbore added 3.5 cubic inches, about a 1% increase in displacement. A tune for that alone is not necessary. If you ever have it tuned in the future, for some other reason, be sure to tell the tuner about the increased bore. On the other hand, on a totally stock engine, you can pick up 10-15 HP simply be leaning out the stock, overly rich PE mode (~WOT) target A/F ratio in the tune.
Old Sep 6, 2019 | 04:06 PM
jarios_'s Avatar
While I had the timing cover off and had the cam and lifters in, this is all while I dont have the pushrods in, I lined up the dots on the cam and crank gears.
Old Sep 6, 2019 | 04:07 PM
jarios_'s Avatar
Also thanks.
Old Sep 6, 2019 | 04:13 PM
I'll move this to “LT1 Based Engine Tech” where you will get more exposure. Not a lot of members come to the “New Member Intro” forum to respond to tech questions.
Old Sep 6, 2019 | 04:33 PM
jarios_'s Avatar
Alrighty, thank you for your input. Also the link you gave me seems to have eased my worries a little thanks.
dodge69874
Mar 22, 2011 05:40 PM
awill12
Sep 28, 2010 12:33 AM
511ERT
May 1, 2010 11:58 AM
93camaroLT1
May 21, 2006 11:46 PM
asia517
Feb 16, 2006 07:38 PM
