1994 lt1 running bad @ WOT.
Old Jun 25, 2007 | 06:56 AM
kline454's Avatar
I have 1994 lt1 under wot its missing and poping putting out black smoke, i tryed everything and problem is still there, changed pcm,icm,plugs,wires,cap,rotor,coil, fuel pressure is good and doesnt drop off. any ideas? no codes.
Old Jun 25, 2007 | 11:13 AM
HardcoreRM125's Avatar
tune ???
Old Jun 25, 2007 | 11:27 AM
LiENUS's Avatar
Try unplugging the MAF, If it goes away either replace or clean your MAF
Old Jun 25, 2007 | 12:58 PM
kline454's Avatar
unplugged MAF problem still there.
Old Jun 27, 2007 | 06:39 AM
kline454's Avatar
well I been driving the car and now it seem to run good, until you sit and let the car get really warmed up then it starts running bad again.
Old Jun 27, 2007 | 08:52 AM
BrianF's Avatar
"replaced the cap and rotor"? I had this same problem in my 94 LT1... I did everything that you have done....
The only thing that helped it was completly changing the Opti-spark... I went to a vented one for the 96'... been a while and dont remember all the details of the swap to a vented vice a non-vented.....
Then it helped even more when I got the Del-teq system with NGK plugs and MSD wires!!!!(I love USAA loans)
Old Jun 27, 2007 | 10:17 AM
kline454's Avatar
i guess it could be the opti but i dont see why it runs great until you let it set and warm up for 15mins??
Old Jun 27, 2007 | 11:42 AM
kline454's Avatar
well now the tack starts jumping when it starts missing.
Old Jun 27, 2007 | 12:32 PM
mrmint69's Avatar
How does it do at 3/4 throttle? My car runs the best at anything less then WOT. I know there are tons of posts on here about performance issues after the car warms up. There should be lots of info in the old ones.
Old Jun 27, 2007 | 12:52 PM
kline454's Avatar
yeah car runs fine at 3/4 throttle.
Old Jun 27, 2007 | 01:10 PM
BMoney's Avatar
I had a problem similar to that, it was my o2 sensor plug, it melted on my header. sending false/bad signals to the computer under full throttle!
Old Jun 27, 2007 | 01:19 PM
Sweetred95ta's Avatar
I know it doesn't address the issue in this thread, but the PCM doesn't get information from the O2's at WOT.
For the OP, have you logged/monitored the car to see how all the sensors are acting as the car gets warmer?
Old Jun 27, 2007 | 01:30 PM
moehorsepower's Avatar
If your tach starts jumping then it is proly your opti, even though you replaced the cap and rotor it is the optical sensor that is bad.....
Old Jun 27, 2007 | 07:45 PM
kline454's Avatar
yeah all the #s look good, seems to be doing it less and less the more i drive it so i dont know we will see what happens.
Red Hawk 94
Mar 18, 2019 04:03 PM
cmdeshon
Jan 4, 2015 11:15 AM
thenewkid
Nov 27, 2014 09:41 AM
Queens94z28
Nov 20, 2014 06:03 PM
IgorT.455/406
Jun 4, 2003 03:32 AM
