1994 Camaro - Gauge overhearing
Old Jan 9, 2020 | 09:42 AM
  #16
Re: 1994 Camaro - Gauge overhearing
Originally Posted by Greg88
i haven’t checked the connector. Is it suppose to be 12v?
I'm puzzled - appeared you looked at the first link in my post #2, Shoebox's guide to testing coolant temperature sensors. You responded you were going to check for the required 12 volts.
I used Teflon sealant (more of a paste) on the current sensor (aftermarket one). I’ve been turning/cranking it in pretty good but people are saying don’t crank it?
Teflon paste or tape is not conductive. Normally there is still some metal-to-metal contact between the male and female threads. But it may be affecting the circuit by increasing resistance on the ground side. Not a common problem, but worth checking. Connector off the sensor, measure the resistance between the sensor's single (positive) pin and the aluminum head (ground). Then check using the iron block as the ground. See if the resistance is close to the value shown in Shoebox’s guide, based on estimated coolant temp. Should not be necessary to excessively torque, and possibly damage the sensor.
new Ac Delco sensor is on its way still just need to go get it.
What brand did you use as the two replacements you mentioned in your first post?
Old Jan 9, 2020 | 09:52 AM
  #17
Greg88's Avatar
I will look into this
i used one called “ultra power 1T1048”
Old Jan 23, 2020 | 03:15 PM
  #18
Greg88's Avatar
UPDATE: changed out the cheap sensor with the AC Delco one and now it works perfect. Thanks for all the help!
Old Jan 23, 2020 | 05:03 PM
  #19
Germansheperd's Avatar
figured that was the issue.
wjogert
Sep 2, 2016 03:54 PM
LT1 POWR
Jun 27, 2011 05:17 AM
flusz28
Aug 5, 2005 08:21 AM
Gearhead6s
Apr 11, 2004 09:50 PM
Camaro37
Apr 22, 2003 04:19 PM
