Hey guys, just installed a 97 engine LT1 into my 94 Camaro. After getting it up and running I’m having an issue with the gauge in the cluster overheating within 20-30 seconds of the car running it’ll max right out. The fans are not turning on which is making me believe the coolant isn’t 250+ degrees hot. I have lots of coolant coming into the rad from the crossover tube, which I could put my finger in after running for 1-2 minutes so it’s clearly not 250 degrees either. I confirmed there is coolant at the sensor in the head as I pulled it out and have put two new sensors in it. When I unplug the connector from the sensor in the head the gauge reads 0, so I’m guessing the wiring is ok? I did use a laser temp reader and the DS head seems to be running a bit warmer then the PS, but then user error comes into play here to with being a bit closer to the headers or maybe water pockets of the heads?
I’m so confused as to what this could be? Is it possible I’m threading the sensor in to far and it’s bottoming out touching the metal head? Maybe the gauge in the car is NFG?
I did put a new 160 thermostat in as well. When I filled the system, I had the bleeder screws open, Filled the block from the T stat housing. Then from the rad cap, until coolant came out of the bleeders and the shut them.
I did the throttle body bypass as well, just plugged the hose from the DS and plugged the hose from the heater core on the PS. I didn’t connect the two, maybe that’s the problem? Here is a pic of what my hose set up looks like:
Do you have a way to scan the PCM for the coolant temp being reported by the temp sensor in the water pump housing? If not, consider downloading Scan9495:
thanks injuneer! I did unplug the connector which dropped the gauge from max down to 0. I will reference it to confirm it’s got the 12v it’s suppose to have.
That will show you all the vital sensor readings, and PCM parameters like status of the fan relays.
I had friend over with a scanner and the WP sensor was reading correctly. Unfortunately at that time the car wasn’t running right (bad opti). So we couldn’t get it up to operating temp, but now I’ll try that. Do I just need to buy a cable that will run from my ODB1 to the PC?
You should have connected the two hoses together when you pulled them off the throttle body base plate. But that shouldn’t cause your gauge issue.
The cable requirements are in the link. May have to read through a few posts to find the latest. You can buy a cable or make on from cheap Chinese parts.
You do have the line from the back of the heads connected to the nipple on the radiator end cap/tank, and not the nipple on the fill cap neck for the reservoir line?
yes I do and it has a steady stream coming into the rad. I had the car running for 10 minutes or so and the temp of the coolant coming into the rad was around 190F.
Did you ever check the voltage on the single wire at the sensor (connector off sensor)? Did you use Teflon tape or paste when you installed the new sensor? Is your new sensor the AC Delco one mentioned in a post above?
i haven’t checked the connector. Is it suppose to be 12v?
I used Teflon sealant (more of a paste) on the current sensor (aftermarket one). I’ve been turning/cranking it in pretty good but people are saying don’t crank it?
new Ac Delco sensor is on its way still just need to go get it.
