1993 LT1 5.7L carburetor/distributor and other conversion.
Old Jul 25, 2022 | 11:39 PM
FireMarshal's Avatar
I purchased a 1993 LT1 on a great deal it came with the proper GM bowtie intake manifold to install a carburetor and distributor, the guy I bought it from had the short block already assembled it has Eagle I beam 5.7L rods, pistons are speed pro H617CP std, heads are 10128374 with the piston and head combo I think it will be to much compression for street driving does anyone have idea of lowering compression possibly thicker head gasket? I'm also looking for a OEM roller style camshaft with good power (going in a 1956 chevy car) for the street and old school rump sound. With concern to the cooling system I know the LT1 water pump and heads are reverse flow any suggestions (electric pump??) I will be using a 1956 chevy car aluminum radiator. If you have additional questions please ask. Please advise on my questions or please direct me we're I can find information. Thank you in advance.
Old Jul 26, 2022 | 03:19 AM
ACE1252's Avatar
Re: 1993 LT1 5.7L carburetor/distributor and other conversion.
Yeah, I'm not sure about those domed pistons. Using this calculator and info from the thread links below, that puts the compression ratio around 13.6:1. I didn't spec the top ring down, so the CR will be a little lower. For the cam, I'm not sure what kind of a lope you are looking for.....almost sounds like you want something similar to a CC306. However, there might be better choices on the cam....so wait for other opinions. I'll also link my CC503 for a comparison. For the cooling....I'm not sure your radiator will cut it.
https://diamondracing.net/p-10-compr...alculator.html
https://www.camaroz28.com/forums/lt1...h-size-851470/
CC306
CC503
GarvinMJ
Mar 20, 2012 10:48 PM
dhirocz
Jan 22, 2007 05:46 PM
dhirocz
Advanced Tech
26
Feb 6, 2006 07:10 PM
aintno6
Feb 18, 2005 08:17 AM
MBonZ28
Advanced Tech
Feb 17, 2004 06:22 PM
