190k LT1 ticking on startup, adjust valves or leave alone?
Re: 190k LT1 ticking on startup, adjust valves or leave alone?
I run mine a little loose, so they tick on startup. If it goes away when warm I wouldn't worry about it. With 200k you will have other problems soon enough.
I am running some 0w 40 in thier for now to swish it around and wash it out. I was thinking that also and probably will change out to 10w 40 when I put new beaings in her.
Originally Posted by SSCamaro
My poor ol 190k engine has a ticking on startup. Once she is the slight bit warm, the ticking goes away. Since, I am assuming it is all stock, the lifters are worn down beyond thier normal clearance? Either way, should I leave sleeping dogs lay or go in and try adjusting them tighter?
As of now, she runs like a bancshee up to 5k quiet as can be when warm.
jb4xx
Feb 2, 2015 10:00 PM
importkiller94
Jan 17, 2015 09:03 PM
