160 Thermostat
Old Jan 12, 2004 | 02:30 PM
SantaCruz163's Avatar
160 Thermostat
why do people switch to a 160° thermostat? What are the benefits of having that over the stocker?
Old Jan 12, 2004 | 02:34 PM
teke184's Avatar
the engine will operate at a lower temperature. and a cooler engine (within reason) is a more efficient engine. keeps the incoming air cooler ...ie denser...for a better air/fuel mixture.
gamecockfan04's Avatar
A cooler engine means, MORE POWER. To get the full affect you need to have the car programmed though. With the stock 180 tstat the fans dont cut on until about 220deg, where with the 160tstat and programming theyll cut on befor 200deg. It s a good mod for $20.
Old Jan 12, 2004 | 04:22 PM
naztyz28's Avatar
orrr you could just get the slp fan switch and turn the fans on whenever you want least thats what i did best money i have spent and i use a 160 thermastat
G-BODYT56
Jan 14, 2022 11:14 PM
Jeff1904
Jun 5, 2016 05:00 PM
chevy94c
Mar 26, 2016 08:53 AM
Bobczar
Oct 23, 2015 11:22 AM
MikeWhitener
Aug 2, 2015 06:17 PM
