160 Thermo guys...What temp do you run at?
Old Apr 26, 2003 | 06:57 AM
Joe K. 96 Zeee!!'s Avatar
I've had mine in for a couple months now. Outside temp has been cool, but the guage on my cluster reads between 160 and 185. About 2/3 the way to 185. So, about 175. Thing is I'm not sure how accurate these guages really are.
Guage stays constant at around 175 on highway or in traffic...cool days or warm. I was wondering if it's getting a reading, but it shows the car warming up normaly when started.
Maybe there's not a problem, but while it's not bad, it just doesn't seem right.
Old Apr 26, 2003 | 08:24 AM
That sounds about normal. Your running temp will be 10º-15º higher than the opening temp of the thermostat. It's still going to be 20º cooler than the 180º thermostat.
Old Apr 26, 2003 | 08:44 AM
joeSS97's Avatar
Thats is right around where mine runs so I would say its normal.In the heat of summer it will be higher.Also need to program the fan settings.Or a manual switch.I use my A/C constantly in the summer so my fans stay on.
Old Apr 26, 2003 | 09:35 AM
Derrick Redd's Avatar
Mine runs 176 degrees according to the scanmaster.
Old Apr 27, 2003 | 07:12 PM
Good...thanks...
Fans are already programed, but the temp never gets high enough for them to come on, but it's not quite summer yet.
Old Apr 27, 2003 | 07:15 PM
dogboy's Avatar
I have the jet fan switch set up so I run about 170 in cold weather and up to 180 in warm. At idle it will go up to 195 before the fans kick in and drop to 180's in traffic.
Old Apr 27, 2003 | 08:29 PM
LimitedEd1LE's Avatar
When I had my car programed the guy said the car would run at 180* with the 160* thermostat in it.
Old Apr 27, 2003 | 08:40 PM
2slow4u's Avatar
Mine is right around 175 by my gauge, although I have never had it scanned. Also programmed the Computer via HPP for the 160
T-stat.
Old Apr 27, 2003 | 09:30 PM
Laymaster's Avatar
Originally posted by BIGKerneL44
any other suggestions?
how about starting your own post instead of hijacking everyone else's? =)
Old Apr 27, 2003 | 09:43 PM
Fbody1's Avatar
I have a 160 and my car runs very cool, last time I data logged it was 65 outside after 20 min of driving (interstate) it finally got to 160, in fla in the mid summer it will run in the 170's, oh I dont have the LT1 stat just the regular chevy small block stat, in the winter it will not eaven get warm enough to put out warn air for the heater(kinda sucks) ,mabey I should I try the hypertech stat?
Old Apr 27, 2003 | 10:21 PM
luis nunez's Avatar
Aroun 185.. to 200 here is very hot... but on highway it is almost at 175-180
Old Apr 27, 2003 | 10:25 PM
Dr.Mudge's Avatar
179º pretty much always, the thermo only begins opening at 160º its not yet fully open.
YellowTransAm350
Mar 2, 2003 03:38 PM
Skull Leader
Aug 10, 2002 11:01 AM
kurob25
Aug 5, 2002 08:03 PM
SavageZ28
17
Jul 14, 2002 11:04 PM
