160 T-Stat
Old Mar 21, 2004 | 11:06 AM
Wildwill2855's Avatar
160 T-Stat
Autozone has the Hypertech 160 Stat availible P/N-1008 for 20.00, Will this work right, I dont have any fan switches or pcm program but will this still operate like it should and keep me below 210 sitting it traffic?
Old Mar 21, 2004 | 11:13 AM
That is the correct thermostat, but it you will heat up in traffic just as before. The only thing different about the thermostat is that it opens 20° sooner than the stock one does. After that, everything is the same. If you have your fans come on sooner, you will stay cooler in traffic. You must have air flow across the radiator to dissipate the heat.
Old Mar 21, 2004 | 11:17 AM
So it will do no good then?
Old Mar 21, 2004 | 11:27 AM
Also I need a new radiator cap everytime i punch it, it spews all over, so I was looking at this from autozone STANT
REGULAR 18Pound System for 7.00, will this work good too? Or should I get their CST cap for 4.00
Old Mar 21, 2004 | 11:36 AM
It will do some good. Since your engine will stay a little cooler while you are moving, it will take longer to get hot when you stop for a bit in traffic. Then, when you get moving again, it will cool down more than it did with the 180. Overall, it should run a little cooler.
Whatever cap you get just make sure it is an 18 psi one.
G-BODYT56
Jan 14, 2022 11:14 PM
chevy94c
Mar 26, 2016 08:53 AM
HarleyZ28
Oct 5, 2015 06:23 AM
tdigger9899
Sep 7, 2015 10:56 AM
Fastbird93
Jul 28, 2002 09:14 AM
