160 stat????
Old Aug 20, 2005 | 09:37 PM
jkucz31's Avatar
160 stat????
what will this 160 stat do for me and how much should it run about and where to buy. when you guys say stat you mean thermostat right
Old Aug 20, 2005 | 10:29 PM
69vette's Avatar
Re: 160 stat????
Search button would help you some in the future. 160 stat is a 160 degree thermostat. With the proper programming, it will lower the operationg temperature of your car. Insted of running at 210, your car will run at 180 degrees usually. You can buy them from many places, including thunderracing.com and ebay
Old Aug 20, 2005 | 10:32 PM
Jazsun's Avatar
Re: 160 stat????
dont buy autozone its regular SBc stat will f up your ride.
Old Aug 20, 2005 | 10:53 PM
LT1Squirrel's Avatar
Re: 160 stat????
i run a regular ole autozone special 160 in my car...it heats up to 160 and rarely gets above that and if it does my fans will handle it
Old Aug 21, 2005 | 01:28 AM
69vette's Avatar
Re: 160 stat????
Theres a reason why they make a lt1 specific stat. I would not be running some sbc 160 like whoever above said but thats up to you. It seems to be working fine for squirrel though.
Old Aug 21, 2005 | 10:10 AM
chuckd4more's Avatar
Re: 160 stat????
I believe they are $12 or $13 on summit. LT1's have reverse flow cooling so you should have a stat for the LT1 and I don't think you can get a 160 LT1 @autozone.
Old Aug 22, 2005 | 11:06 AM
aaron_depue's Avatar
Re: 160 stat????
The sbc 160 degree sstats from autozone are shorter than thw LT1s. I installe one 1 week ago and my temp hasnt got above 160 yet and I made a 2 hour drive this week and stil didnt get over 160. Does that sound right.....? I leaked a little coolant onto the ground but it wasnt very much (about a pint). My OEM temp gauge hasnt moved yet. Does this sound like a problem?
Old Aug 22, 2005 | 11:13 AM
2000GTP's Avatar
Re: 160 stat????
I picked mine up from Summit for 18.00. It has yet to be installed as I am waiting to send out my PCM to be tuned by Madz28.com
Old Aug 22, 2005 | 11:56 AM
Re: 160 stat????
The SBC thermostat is not the correct one. Why? Because the cooling passages (at the thermostat) are nothing like the old SBC. It may or may not work properly depending on how hot it is out. You can do what you want, but the right thermostat is the long one. As fragile/important as the cooling system is to the LT1, I prefer to use the correct stuff.
Old Aug 22, 2005 | 12:27 PM
Ray86IROC's Avatar
Re: 160 stat????
What effect would the 160 stat w/o the programming to turn the fans on sooner have? Certainly wouldn't hurt anything right, have to run at least a little cooler wouldn't it?? Does not one of the fans come on whenver the A/C is on regardless of current temp? My car rarely gets up hot enough to run the fans anyway it seems.
Old Aug 22, 2005 | 12:34 PM
69vette's Avatar
Re: 160 stat????
It will open a little sooner but it is still going to heat up to watever the fans are set at. It may run cooler on the highway where you have enough air.
G-BODYT56
Jan 14, 2022 11:14 PM
chevy94c
Mar 26, 2016 08:53 AM
tdigger9899
Sep 7, 2015 10:56 AM
Rich_z28
Sep 13, 2002 03:35 PM
jeff94z28
Sep 11, 2002 02:01 PM
