160 degree thermostat
? for the ones that have installed the 160 degree thermostat . What temp did you program your PCM for the fan to come on and then what temp did you program for the fan to shut off.
I used the HPP and adjusted the fans for the 160* thermo, and my car won't go over 180. When I have a need to get my PCM tuned I'll have the fans come on around the same, seems to be wroking well....
